bms.bin8051 Code dump from a GEN2 BMS module.octet-stream - 15.00 kB - 01/14/2018 at 20:21 |
code2.BIN8051 code dump from another moduleoctet-stream - 7.36 kB - 02/27/2017 at 07:10 |
wiring.pdfExample diagram showing wiring of the J1 connectors to the master BMS board.Adobe Portable Document Format - 78.17 kB - 02/21/2017 at 06:47 |
Adobe Portable Document Format - 332.76 kB - 02/21/2017 at 06:20 |
TeslaBMS_02.pyV0.2py - 4.37 kB - 02/20/2017 at 04:57 |
code.lstDiassembled with DASMxlst - 179.14 kB - 04/18/2016 at 00:37 |
code.hexRaw 8k flash dump from the uC using the C2 debug interface. Viewable in a hex editor.hex - 8.00 kB - 04/18/2016 at 00:37 |
