Bus-Hold Contemplations
A project log for sdramThingZero - 133MS/s 32-bit Logic Analyzer
Add an old SDRAM DIMM to your SBC for a 133MS/s 32-bit Logic Analyzer, add ADCs for a Scope...
eric-hertzEric Hertz 10/27/2016 at 14:420 Comments
Bus-Hold, briefly: (see, e.g. TI's explanation http://www.ti.com/lit/an/scla015/scla015.pdf)
For a system where several devices are connected to a bus, there may be times when *none* of the devices are selected to output a voltage onto that bus.
In which case, the input-voltage to all the devices will "float", and, briefly, that's not good.
In one case, *both* transistors (the N and P-channel mosfets) will be active at the same time, causing somewhat-significant power-consumption. (did I see 5mA per input?!)
In another case, the input-circuitry will *oscillate*... And that causes even higher current-draw, but also injects a bunch of noise into the entire system... (decoupling capacitors?)
Bad idea, probably, to allow this to happen... but is it really *bad* per-se...? Are there cases where it doesn't matter, much? I'm not too worried about power-consumption, as a hobbiest trying to build something that works. And, maybe, decoupling-capacitors are good-'nough to prevent oscillation from escaping from an otherwise *deselected* (non-outputting) chip into the other circuitry that is functioning...
They've already created ICs that have "bus-hold" circuits built-in. These circuits basically take the input, feed it through a buffer, then feed that output back to the input with a resistor. (side-note on how that's quite similar to my use of resistors in signal-routing, and as well for my original design of the trigger-handler latch).
Then, why not just use these chips that have bus-hold, and call it a day...? They don't cost much more, (in fact, at my supplier right now, they're cheaper).
They do, however, take a (tiny) bit of extra input-current... worst-case nearly half a milliamp, *each*... during switching.
But that application-note shows a good example... what when you've got 8 devices on the same bus, all with bus-hold on their inputs.... Well, most devices are capable of switching 24mA, these days... so "negligible effect"-ish... great!
(Still, does that make sense when talking about .5mA * 8 = 4mA, AND they actually discussed devices with 4mA outputs? Huh... suddenly our switching-speed is slowed, dramatically, no? While not only dealing with that 4mA of load, we've also got to overcome input-capacitances... huh.).
But then the next example is the kicker...
What happens when you've got pull-up/pull-down resistors on your bus...? Read that section (or skim)... Basically the jist is, their calculations show that where once a 10-100k pull-up/down resistor would've worked, now you need less than 3k, and that's only with *one* bus-hold device connected!
(The weird thing is, some of these manufacturers give the *same* datasheet for both LVT and LVTH, surely these numbers (input characteristics) are quite different for these two. And I'm almost certain they showed only one set of numbers. Huh.)
One more time... whereas previously a 100k resistor would've been enough for a pull-up, now we need less than 3k. That's pretty significant. Nowhere *near* "negligible."
Which means I should probably reread that section and understand/do that math myself. And maybe look into the other bus-hold topologies (e.g. those from the NXP sheet: http://www.nxp.com/documents/application_note/AN2022.pdf)
And... maybe not assume that just because they have the same family-designation means they work the same (74LVT[H] from e.g. NXP vs. TI).
Because, in part.... you may recall from previous logs, I've been trying to get away with using resistors to direct signals back across the latches (in the reverse-direction), rather than using buffers with output-enables (requiring more control-signals).
Whelp, those resistors, essentially, look like pull-up/pull-down resistors (their polarity just happens to be driven by a device on the bus). So, I don't know how much smaller they might need to be... I was already thinking about something along the lines of 470ohms (since I happen to have a *lot* of those resistor-networks)... but, yahknow, that might have to be decreased even further if my system has a lot of bus-hold inputs. Something to think about, and not something I really have the brain-power *to* think-through in the next few days...
So, my original order, before I even began reading-up on bus-hold, was going to be for 10 of each: LVT without bus-hold, and LVTH with... and I'd figure it out when I had the parts... I guess that's what I'll do. Unfortunately, the supplier doesn't have the LVT in SOIC, and the LVTH in SOIC is a min-quantity of 25... So, first, I thought maybe getting *all* with bus-hold (in the much-more-prototype-friendly SOIC) would be acceptable, with a bit more reading-up... but I guess I'mma stick with the original 10/10 order of TSSOPs (oy).
And, all this leads to the intricacies of trying to make this thing capable of 133MS/s... Again, we've already got 30MS/s with some decades-old parts I had lying around... Surely more than useful to build over a weekend... But if you want 133, you're gonna need a well-thought-out layout (PCB) and specific parts, or I'm going to have to design it with these sorts of things in mind.
