First Version of the new, modular BeeStalker
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
johannwilhelmjohann.wilhelm 11/12/2016 at 15:210 Comments
Time's going on, so the BeeStalker-Logger gets a new schematic...
Now everything is based around a RPi Compute Module.
This is only the main-board. A battery-board and the actual weight scale is coming soon...
73
