VHDL FIFO
A project log for muCPU: an 8-bit MCU
An 8-bit load-store CPU with 2 pipeline stages, designed in Logisim and implemented in VHDL + assembler written in Python
reed-fosterReed Foster 05/04/2016 at 00:153 Comments
Slowly, but surely, the VHDL code for the controller is coming along; I've just finished a structural architecture for a FIFO queue (first in first out). In a FIFO, data is "enqueued" (pushed in a stack) and "dequeued" (popped in a stack). However, the cool thing about queues (and stacks, for that matter) is that only a value must be supplied; the stack handles addressing. Below is a sample of enqueueing and dequeueing using a FIFO queue:
iSim Waveform of FIFO simulation (vhdl on github)
Yann Guidon / YGDES wrote 05/04/2016 at 01:06 point
FIFOs are notoriously tricky designs. The synchronous version is easier though.
I'm trying to understand how you made yours, I should read the source code instead of decyphering the waveforms :-)
May I recommend GHDL for simulation ?
Reed Foster wrote 05/04/2016 at 01:10 point
Yeah, the waveform is more for show than actual documentation. Also the test code that I ran for the simulation doesn't fully demonstrate the stack because it reads all of the data out of the FIFO. I'm pretty happy with iSim for debugging because all I have to do is click on a button in Xilinx's IDE and it runs the simulation for me, but I'll be sure to check out GHDL though.
Yann Guidon / YGDES wrote 05/04/2016 at 01:23 point
I developed the 3R block with GHDL, which is very strict so I'm sure the code can be ported almost anywhere. I'm reading your source code now :-)
