load images over uart on the display - the simple way
A project log for 192:LED
Extreme tiny (0,68'‘ x 0,68’‘ or 17mm x 17mm) smart RGB LED display/matrix
alexAlex 07/02/2016 at 16:190 Comments
In the last log I wrote about a quite complicated way to load images to the display. I now have improved the octave script. it no loads the image itself to the display:
This is done by using the instrument-control package of octave:
function IMG_test
  pkg load instrument-control
  if (exist("serial") != 3)
    disp("No Serial Support");
  endif
  myImage = imread("image.png");  #read 8x8 pixel image
  # the image is vreatet with MS paint. At least there each
  # pixel is encoded into three bytes (R,G,B) this could be
  # normal for png. At least I hope so
  # now to the conversation magic
  red   = uint8(bitshift(myImage(:,:,1), -5));
  green = uint8(bitshift(myImage(:,:,2), -5));
  blue  = uint8(bitshift(myImage(:,:,3), -5));
  #add the three colors to one byte togehter
  img8trueColor= bitshift(red,5) + bitshift(green,2) + blue;
  #transpose the image - needed to save it correctly
  img8trueColor=img8trueColor.';
  #write it to display direct in octave no more a file output
  s1 = serial("\\\\.\\COM12");
  set(s1, 'baudrate', 38400);
  srl_flush(s1);
  srl_write(s1, img8trueColor);
endfunction
The source code is also in the github repository.
helpful links for octave and uart:
http://wiki.octave.org/Instrument_control_package
http://www.edn.com/design/analog/4440674/Read-serial-data-directly-into-Octave
http://projectsfromtech.blogspot.de/2015/03/serial-port-communication-with-gnu.html
