DPS-1520AB Server Supply Hotswap Breakout
Power Breakout for RC Chargers and ASIC Miners
Allows for quick changes from supply failures should they occur, or for large scale mining operation installs & RC charging supplies
I wanted an easier way to connect power and seen other boards available for server supplies that looked great but none that i found for the DPS-1520AB. series supply
so I set out and made my own based on various pinout information found online
The Supply Side receptacle: (ON THE DPS-1520AB)
Internal Header (Amphenol FCI Part: 51939-104LF)
Breakout Board Side hotswap:
PCB Header (Amphenol FCI Part: 51915-101LF)
pci-e connectors: (18awg 7.5A 30 Deg C max temp rise 32.2 max per pin)
Molex 6 Pin pci-e connector (Molex part: 0039281063)
Connectors to connect to pcb via wires
6 Pin PCI-E Male Connector (Molex part: 0039012060)
Crimp pins for 14-18awg wire:
Crimp Pins (Molex part: 0039000038)
the two solder jumpers are for power and fan speed
Also I would recommend using 2oz copper if you make one
brd - 92.24 kB - 07/01/2016 at 19:52
Download
sch - 39.62 kB - 07/01/2016 at 19:51
Download
irun4fundotca_rev5.lbr
Updated Library
lbr - 29.63 kB - 07/01/2016 at 19:50
Download
Correct Connector for PCB 51915-101.pdf
Breakout side connector 51915-101LF
Adobe Portable Document Format - 224.08 kB - 06/23/2016 at 19:31
Preview
Download
Adobe Portable Document Format - 257.04 kB - 06/21/2016 at 22:14
Preview
Download
View all 8 project logs
View all instructions
zebcrs wrote 01/10/2023 at 18:37 point
Is there any way to adjust output voltage on theese ? I have two and I need to get 13,7 Volts out of them to supply cars while programming.
coquitoc98 wrote 07/15/2021 at 01:08 point
Hello, will anyone have the diagram of dps-1520ab? I need to repair the circuit where the ice 2a180z is and the zener diodes are disintegrated.
Gatchaman wrote 07/14/2016 at 17:53 point
I'm building a server cluster box and have 2x HP 412138-B21 2250W Redundant Power Supply Unit for BLC7000 with what I think is  this male connector FCI 51939-183LF or 51939-186LF.
https://sites.google.com/site/hpc700012vpowersupply/
Having a bit of trouble finding the receptacle, female socket to the above male header. There are so many designs and the data-sheet doesn't  mention the part. Trying to find the female part is a nightmare on digi-key and mouser...... :-(
irun4fundotca wrote 07/14/2016 at 18:02 point
contact Amphenol FCI and  they will help using the online chat feature
then the same goes using digikey also for finding it if they have stock that is
they require a large min order quantity though if not in stock
there are premade ones for most supplies here
https://bitcointalk.org/index.php?topic=738527.0
Gatchaman wrote 07/14/2016 at 22:17 point
Thanks for the info. Will ask about the interface tomorrow. I've already been to the bitcointalk page but nothing was produced for the 2250w psu as far as I could tell.
Gatchaman wrote 07/19/2016 at 11:00 point
After looking at a few data sheets and ordering the wrong connector
(cough) I got a reply from a few emails to Mouser and FCI with (hopefully) the right part number.
Mousers postage cost to the UK is a killer so I'll have to buy a few connectors to make it worth it. Mouser Part No: 649-51915-072LF
I bought 8 pin pci-e power connectors for my DIY cluster power board to spread the load over the cables.
Now I need to learn how to use a CAD program...... sigh and find a UK pcb producer. I'm clueless.... Any reccomendations?
Now dusting of my copy of Eagle....
Charles Lakins wrote 06/23/2016 at 21:37 point
between $25-39usd search ebay for DPS-1520AB
Arya wrote 06/23/2016 at 20:51 point
Awesome project! How much do these supplies cost typically?
irun4fundotca wrote 07/14/2016 at 17:57 point
about $25CAD
