1Step 1
The first step is to find a suitable computer and camera.
For the computer, I suggest any cheap computer that is capable of some basic image processing. I'm using an RPi 3 and it is completely sufficient.
The camera part is a little harder. You need to find a camera that is capable of low light imaging. I have a canon digital camera that I am using for my rig, but I've even had success with the PiCam in low light situations.
2Step 2
Once you have everything hooked up make sure you have python 2.7 installed and OpenCV (here).
3Step 3
Pull the repo from git:
git clone https://github.com/heidtn/MeteorTracker
Install pip if you don't have it:
sudo apt-get install python-pip
Install numpy and sqlite3
pip install numpy sqlite3
4Step 4
Now go into the MeteorTracker directory and run:
python setup.py
5Step 5
Put together an enclosure for your tracker.
I packaged mine inside of a coffee can. I cut a hole in the lid for the camera and one in the side for the power. I ran an extension cord from the house to the power cord for the RPi.
I sealed the usb regulator in a plastic bag with the power cord. It almost never rains where I am, but in the few light rains we've had, this setup has done fine.
6Step 6
Find a good place with a clear view of the sky and as little light pollution as possible.
As of now you have to manually start the program. My Pi is within WiFi range and I can ssh into it from home to start everything.
Now execute the following to start the tracking program:
nohup python MeteorTracker.py &
This will start the program and it will continue to run event after you log out.
