garage-door-opener.schSchematic v1.0 - Note: There is an error in this version - the TX/RX pins on the FTDI connector are swapped (From what seems to be the standard pinout)sch - 225.95 kB - 08/01/2016 at 02:26 |
garage-door-opener.brdPCB v1.0 - Note: There is an error in this board - the TX/RX pins on the FTDI connector are swapped (From what seems to be the standard pinout)brd - 94.33 kB - 08/01/2016 at 02:26 |
