ezx_filter.cUpdated for ezx 2D library and new sscanf() behavour.x-csrc - 8.38 kB - 12/09/2018 at 03:55 |
ezxdisp-0.1.4.tar.gzThe new 2D graphics library.gzip - 160.44 kB - 12/09/2018 at 03:53 |
FilterGCode.runA Linux Mint (X11) version- 21.87 kB - 10/22/2017 at 08:40 |
application/x-msdownload - 39.00 kB - 08/20/2016 at 12:46 |
FilterGCode.exeThe Windows executablex-msdownload - 38.00 kB - 07/27/2016 at 15:23 |
fish6.ncA particularly terrible G Code file with way too many segments.Network Common Data Form (NetCDF) - 706.74 kB - 07/27/2016 at 15:24 |
FilterFishesForLaser.batAn example batch file that uses a 0.01 mm tolerance and suitable for a laser engraver.bat - 62.00 bytes - 07/30/2016 at 12:02 |
LaserFish6.ncThe filtered laser engraver G Code file.- 29.30 kB - 08/20/2016 at 12:37 |
FilterFishesForRouter.batAn example batch file that uses a 0.01 mm tolerance.bat - 58.00 bytes - 07/30/2016 at 12:02 |
MillFish6.ncThe filtered router or mill G Code file.Network Common Data Form (NetCDF) - 30.75 kB - 07/30/2016 at 12:03 |
cbp - 762.00 bytes - 08/20/2016 at 12:37 |
filter.cThe G Code Filter C code.- 11.02 kB - 08/20/2016 at 12:46 |
libBGI.aThe BGI Graphics Library if you want to compile the code yourself (Windows only)a - 47.48 kB - 07/27/2016 at 15:24 |
graphics.hThe header file for the graphics library.h - 10.11 kB - 07/27/2016 at 15:24 |
gcodesender.exeSaves you finding it to download.x-msdownload - 747.50 kB - 08/20/2016 at 12:46 |
