Standalone Energy Circuit
11/02/2016 at 21:49 • 0 commentsNow I have a battery for my console. I'm gonna add it.
It's a classic phone power bank. Just unmounting it to save space.
Preparing the raspberry system
09/01/2016 at 10:38 • 0 commentsTo play retro games in the raspberry pi, you need a simple system to wire the button.
That's why i used Recalbox. Tutorials are in Recalbox's website.
Then when you finished making the recalbox sdcard, turn on the raspberry pi and wait 5 minutes (take a coffe :p ). The system is creating the good recalbox (depending of your raspberry pi model).
When it start, you can see something like this :
my config.txt (for the scale and more) :
Just a thing to know :
The share folder can have some bug (for me with the 4.0.0-beta-4 version of recalbox).
If the games you add aren't display when you turn on read bellow.
To access this folder, you MUST TURN ON the raspberry pi with recalbox, and add roms by the local network, or ftp, something like that.
If you don't do this, it would really add the games. I don't know why.
A video composite cable for the raspberry pi 2
09/01/2016 at 09:51 • 0 commentsIn fact, a lot of people will injure me after that, but i know some other will love this post.
I soldered a cable to my raspberry pi 2. Yes i did it.
(more details here : http://www.instructables.com/id/Raspberry-Pi-2-Quick-n-Easy-RCA/step4/Alternate-Method/ )
With this, all you have to do after is to make your raspberry display the system with the composite display (no hdmi).
My config.txt (in the raspberry sdcard boot partition) :
(comment links are dead)
The screen
09/01/2016 at 09:36 • 0 commentsI buy a 4.3 tft lcd screen. I take it from a reversing camera for cars (more details in the components list). The resolution isn't so bad. Anyway, old video games doesn't have 4K resolution. I keep the cable, it's usefull to test the circuit.
A thing to know : you have 3 cables. Red for the alimentation, yellow and white for the composite signal.
Screen power supply : 9-12V.
I found an AC DC Adaptator (from an old alarm clock). You can also use an Universal adaptator, or a lot of battery to test the screen.
The last thing to know : the screen turn on ONLY IF YOU ENTER A SIGNAL IN COMPOSITE (and the power supply to of course).
I said it.
