MQTT_ESP8266_MHIv1.inoCopy of the source code I use to run the ESP8266 circuitino - 14.37 kB - 09/03/2016 at 14:07 |
ACIR.xlsxWorking file for decoding the IR signal - contains extracts from AnalysIR, Map of IR codes, and sheets of unit tests.sheet - 48.24 kB - 09/03/2016 at 14:03 |
MitsubishiHEavyIndustriesAirCon_IR_Map.pngMap of the decoded IR signal for a Mitsubishi Heavy Industries Air con (DXK series).Portable Network Graphics (PNG) - 59.15 kB - 09/03/2016 at 14:02 |
