This unit was built using scrap acrylic and is very rigid. Some parts are metal, others are 3D printed
As much as I like using Mach 3, I am going to replace the electronics with a RUMBA or ordinary RAMPS. I lile the idea of a single carriage with multiple, vs interchangeable heads and the RUMBA lets me do this. I will do the same for the 3-in-1
I sorta built it as I went along. Here is a preliminary set of parts:
1) Left side (gantry) - 6mm acrylic
2) Right side (gantry) - 6mm acrylic
3) Table Plate -- acrylic
4) Table Plate Side, Left -- acrylic
5) Table Plate Side, Right -- acrylic
6) Table Plate back plate -- acrylic
7) 8mm Rod supports (metal or plastic) x 6
8) Y leadscrew
9) X leadscrew
10) Z leadscrew
11) Table support blocks x4 (plastic), 3D printed
12) Table bearings and pillow blocks (LM8UU) x 4
13) Leadscrew coupler x3
14) NEMA 17 or 23 motors (I am using 17) x 3
15) MDF table (200mmx200mm)
16) Y axis 8mm rods x2
17) X axis 8mm rod x1
18) Z axis 8mm rod x1
19) Leadscrew bearing and mount x3
20) Printed Z carriage (note, NOT X carriage)
21) Z carriage plate -- acrylic
22) Stepper L-shaped mounts x2
23) Z carriage T-nut x2
24) X carriage T-nut x2
25) X bearing and pillow block (LM8UU) x1
26) Z bearing and pillow block (LM8UU) x1
27) 8mm Rod clamps x2
28) L-shaped brackets (1"x1") x4
29) A lot of M3 hardware (screws, nuts, washers)
For electronics, I will probably put in a RAMPS or a GRBL-Pi on a Model B+ RasPi, and mount it to the side
Looks interesting - do you have it documented somewhere in more detail than just one photo?
This is actually what will become my 3-in-1. I based this on my CNC machine, and use a flying gantry with a few printed parts. My intent is to install a 'head' that holds a spindle and run the whole thing off either a Sanguinololu board or a RasPi with a GrblPi board on it (using Teacup). I am still gearing up for this but the intention is to also replace each acrylic panel with an aluminum equivalent just to make it stronger and more rigid. I want to keep it to desktop dimensions with the table currently at 6"x6" but I easily scale up to 8"x8" by widening the bed and using longer rods. The most I imagine this unit being is 18"x18" which may be sufficient for most. Really large scale machines have already been done. I can easily, for example, also extend my ShapeOKO to be a printer and laser engraver with different electronics. What else would you like to know?
Thanx for the reply. TBH nothing specific. My mind is walking through the similar route currently - just without my own CNC machine currently ;) I am planning to do a desktop CNC diode laser engraver / dremel mill and are considering using acrylic for first version before I go for 6mm aluminium (which seems to be the tickest aluminium plate available around here within reasonable budget). And as you used 6mm acrylic it sounded like a good read if its more completely documented to see what would be the typical issues one can run into when taking that route. The local MAkerlab has a laser that can cut acrylic but for metal parts I would have to get some local metalworking shop to do the cutting which can be quite a pricy for a unique set of parts.
I cut my own metal parts as well as tge acrylic. I use a scroll saw or jigsaw with a metal bit and drill out holes with a press. For the acrylic I highly advise you not use nuts and use thermoplastic inserts instead. I will tap holes in my aluminum. I may also cover my acrylic with sheet aluminum bonding it to the acrylic for strength. With the inserts in place I can lock screws in with stronger hardware and apply more torque to them. If you need any kind of help let me know.
can you paste all parts list?
