PCB redesign - rev2
07/16/2018 at 12:51 • 0 commentsThe PCB has been redesigned - we've decided to use SMD parts which can be placed using a pick-and-place machine and left the LEDs to be assembled by hand. This makes it easy to turn it into a DIY kit which doesn't require a huge amount of soldering - just the LEDs. With this redesign, we've addressed the PWM issue - we can now display the whole color spectrum using generic RGB LEDs.
Si7021 now supported as an environmental sensor
05/07/2018 at 20:40 • 0 commentsI've added support for another inexpensive environmental sensor - the Si7021. It is pin-compatible with the HTU21, so you can use both interchangeably. The software will automatically detect and report which sensor is attached upon startup.
Slight rewiring required to get PWM to work
05/02/2018 at 13:19 • 0 commentsWe've discovered that there's a problem driving our LEDs via PWM - the library we're using doesn't let us use GPIO16 as a PWM pin. We think the best way to solve this would be to rewire the pins around a bit.
INPUT / OUTPUT LABEL OLD GPIO NEW GPIO HTU_SDA GPIO5 GPIO0 LED_B_CTRL GPIO16 GPIO5 HTU_SCL GPIO4 GPIO2
