bldc_driver_gerber.tgzBLDC motor driver GERBER files for PCB productionx-gtar-compressed - 33.37 kB - 05/27/2018 at 16:37 |
bldc_driver.pdfSchematic of the BLDC motor driverAdobe Portable Document Format - 20.97 kB - 05/27/2018 at 16:37 |
motor_adapter.pdftechnical drawing of the motor to pump adapterAdobe Portable Document Format - 59.60 kB - 05/27/2018 at 16:36 |
mount.pdftechnical drawing of the actuator mounting elementAdobe Portable Document Format - 24.81 kB - 05/27/2018 at 16:36 |
top_block.pdftechnical drawing of the actuator top blockAdobe Portable Document Format - 60.23 kB - 05/27/2018 at 16:35 |
bottom_block.pdftechnical drawing of the actuator bottom blockAdobe Portable Document Format - 66.61 kB - 05/27/2018 at 16:35 |
mechanical_dxf.tgzSet of technical drawings of all mechanical parts in DXF format.x-gtar-compressed - 28.18 kB - 05/27/2018 at 16:34 |
