Timing
A project log for BREDSAC
Electronic Dynamic Storage Breadboard Computer
gregewinggreg.ewing 06/02/2018 at 09:520 Comments
BREDSAC will operate on an 18-bit basic cycle, corresponding to a short word.
Because some operations require reading and writing back to the same
register, each bit time will be divided into two phases. In the first
phase a read may occur, and in the second phase a write may occur.
To allow for generation of the memory and register oscilloscope
displays, each of these phases will be further divided into two
subphases, one for the display system and one for the CPU.
The RAMs I'm using for the main memory and registers both have a cycle
time of 500ns, giving a bit time of 2us. Coincidentally, this is the
same as the bit time of the original EDSAC. However, the EDSAC had a
variable memory access time due to the need to wait for the word you
wanted to come around in the delay line, which could take as long as 32
short word times, or 1.152ms. The BREDSAC, with truly random access
memory, will be considerably faster.
