The horizontal force (along with wind force) on a floating object can be oppose by anchore it properly ( by using four long distance anchors ) so that the vertical force remain almost same. This vertical force is useful. For example It can be very much useful as easily increase this vertical force by increasing the size of the object. This bidirectional vertical force is very much suitable for pumping purpose. By using the vertical force of tidal wave sufficient amount of water pumping possible for hydro power generation.
Details
This is the right way to collect maximum amount of energy from tidal wave. It can solve the demand of world's electricity.
Site selection : We visited 4 sites in last two days, ocean side tidal conditions is ok, besides coastal areas are ok for reservoir and hydropower station. Thinking about soil test.
Unlimited source of energy “Ocean tide” can provide low cost zero emission reliable electricity (unlimited). Tidal energy Is the form of visual mechanical force so it conversion technique shouldn’t be difficult .
"Wave power works when other renewables don't, but energy companies have failed to harness this constant source of energy. Now all that is about to change."
This is a very easy technique to harness energy from ocean tidal energy as already running some small projects. Capacity can be increase as required by increasing the size of the object and pump very easily. Expensive waterproof devices not required for this easy technique. Compare to the other hydro power stations dam, big reservoir, big catchment area not required so cost effective. Also other facilities will be there.
Articles in Press
https://www.scitechnol.com/ArchiveJNPGT/articleinpress-nuclear-energy-science-power-generation-technology.php
