Test for the highest light level.
07/16/2018 at 02:54 • 0 commentsOne of Sun Chaser’s main functions will be to find the area of the brightest light level. Two curved surfaces with six photo resistors are used to form a 360 degree light level direction indicator. The video below shows the test of the 360 degree light level sensors. So far, so good!
Curved surfaces added.
07/14/2018 at 01:18 • 0 commentsThe curved surfaces used to determine the direction of the greatest light with six photo resistors is complete.
Below is Sun Chaser with the curved surfaces installed.
Photoresistors arrived from Digi-Key!
07/07/2018 at 23:36 • 0 commentsThe photoresistors arrived from Digi-Key. Now I can assembly the curved surface to detect the direction of the greatest sunlight.
Starting the Build
06/29/2018 at 01:10 • 0 commentsThe first Sun Chaser is being built from a lot of re-purposed materials. After testing and working out the bugs, another more reproducible version will be built. The beginning of the Sun Chaser is a re-purposed aluminum cover that will now be the bottom plate of the robot.
Two pieces of aluminum channel and a four strips of sheet aluminum can make a good motor mount. The motor wires are routed through holes with grommets to protect the wires.
Next, four stand offs and the Squid motor driver is mounted.
