BinMonitored.zipSource code (Compile in Arduino IDE with generic ESP8266 module selected).x-zip-compressed - 12.73 kB - 10/01/2018 at 02:57 |
BinMonitoreLidFull.dxfLaser cutting file for a full width lidAutoCAD DXF - 79.69 kB - 10/01/2018 at 00:04 |
BinMonitoreLid.dxfLaser cutting file for the smaller lid which fits inside the enclsure lip.AutoCAD DXF - 80.03 kB - 10/01/2018 at 00:04 |
BinMonitoreLid.svgSVG original for Laser cutting filesvg+xml - 3.93 kB - 10/01/2018 at 00:04 |
BinMonitoreLidFull.svgSVG original for Laser cutting filesvg+xml - 4.12 kB - 10/01/2018 at 00:04 |
BinMonitoredBigLid.stlLarge lid, ideal if you use 3mm acrylic on the inner lip of the enclosre then put this on top .simplify3d_stl - 370.98 kB - 10/01/2018 at 00:03 |
BinMonitoredLid.stlNormal lid, fits inside the lip.simplify3d_stl - 245.39 kB - 10/01/2018 at 00:03 |
BinMonitoredEnclosureBody-PCBRecessed.stlEnclosure with the PCB recessed a little more so it can be encapsulated in epocy.simplify3d_stl - 225.18 kB - 10/01/2018 at 00:02 |
BinMonitoredEnclosure-5-Narrow.stlStandard Enclosuresimplify3d_stl - 231.53 kB - 10/01/2018 at 00:02 |
BinMonitored.schEagle Schematicsch - 484.70 kB - 09/30/2018 at 19:51 |
BinMonitored.brdEagle board filebrd - 94.43 kB - 09/30/2018 at 19:51 |
PcbTop.pngPcb Top LayerPortable Network Graphics (PNG) - 72.81 kB - 09/30/2018 at 19:51 |
PcbBottom.pngPCB Bottom LayerPortable Network Graphics (PNG) - 48.22 kB - 09/30/2018 at 19:51 |
PcbAll.pngPcb (All Layers)Portable Network Graphics (PNG) - 130.40 kB - 09/30/2018 at 19:50 |
Schematic.pngSchematicPortable Network Graphics (PNG) - 382.23 kB - 09/30/2018 at 19:50 |
BinMonitored-V1-Gerber.zipGerberx-zip-compressed - 57.21 kB - 09/30/2018 at 19:50 |
