supercon_bezel.cdrBezel which should be glued to the back of the bezel, to protect components from your fingers. The best material is transparent acrylic, 4 or 5 mm thick. This file is in CorelDraw Version 11, which is compatible with most laser cutters.cdr - 23.89 kB - 11/07/2018 at 23:29 |
Proto Board 2018 Outputs.zipGerber files and PCB file (CircuitStudio) for the proto PCBx-zip-compressed - 1.33 MB - 10/23/2018 at 23:38 |
Supercon 2018 Badge Outputs.zipGerber files and PCB file (CircuitStudio) for the main badge PCBx-zip-compressed - 2.52 MB - 10/23/2018 at 23:38 |
LIS3DH.pdfLIS3DH accelerometer (16-bit reading)Adobe Portable Document Format - 682.96 kB - 10/23/2018 at 22:59 |
LIS3DE.pdfLIS3DE accelerometer (8-bit reading)Adobe Portable Document Format - 1.01 MB - 10/23/2018 at 22:59 |
Adobe Portable Document Format - 2.89 MB - 10/18/2018 at 05:50 |
Adobe Portable Document Format - 3.05 MB - 10/18/2018 at 05:50 |
Adobe Portable Document Format - 4.12 MB - 10/18/2018 at 05:50 |
Adobe Portable Document Format - 1.95 MB - 10/18/2018 at 05:50 |
Adobe Portable Document Format - 696.96 kB - 10/18/2018 at 05:50 |
