Full matrix design
05/30/2021 at 15:27 • 0 commentsJust to get a first impression about the matrix, 90cm diameter, 70 cm height:
Large matrix design
05/29/2021 at 09:34 • 0 commentsThe grid for the new large cylindric matrix (right now 84x20 LEDs) is designed in Fusion360 as a full parametric design, so by changing the number of LEDs for x and y and the material thickness, Fusion automatically redraws the matrix segment. I will use 30 LED/m stripes, so the diameter is close to 1 meter.
To make assembly and transport easier, the design is made for a quarter of the cylinder ,which then later will be combined with 3 other quarters to the full cylinder. Next steps in the design process are:
- mounting of the LED stripes
- connection of the quarters
- cable guiding
Also started to model the matrix in P5.js to do some animation simulation.
Github
03/08/2019 at 16:03 • 0 commentsFinally added the source code to my GitHub.
Just the test code from the video ;-)
Software simulator
10/28/2018 at 14:51 • 0 commentsAs in my previous LED matrix project, I am using a pygame based simulator for testing the python code on the PC. Code will follow soon on Github.
LED assembling
10/24/2018 at 14:07 • 0 commentsHere are some more pictures from the LED assembling:
Matrix body
10/24/2018 at 05:54 • 0 commentsHeight is 18 cm, diameter is 20 cm
