Hypno Butt
An analog light and sound circuit sculpture of a popular Internet meme in deadbug style
Hypno Butt is constructed of brass wire, closeout bin and scavenged through-hole components. Light and sound patterns are made via a mixture of flicker candle LEDs, 555 timer, and hall effect sensor. He draws power through his feet. 9 Volts are his favorite but 5V will work if slumming it.
  • 1 × LM555 Clock and Timer ICs / Timer ICs
  • 2 × Flicker LED
  • 3 × 1N4148 diode
  • 1 × 30 AWG wrapping wire
  • 1 × U18 hall effect sensor
View all 12 components
  • Done for now
    Jeffrey Jacques01/16/2019 at 10:14 2 comments
    I feel pretty good about where this project is now but might revisit it sometime when I have access to a proper o-scope. Since I believe this is a novel 555 circuit using both the flicker LEDs and Hall effect components I'd like to know exactly what's happening. I've posted my theory in the comments.
View project log
Yann Guidon / YGDES wrote 12/27/2018 at 08:57 point
9GAGers would be crazy...
Jan wrote 12/27/2018 at 12:31 point
More 4chan than anything, really. 9GAG is just the waste-collector of the internet, directly followed by facebook :)
4chan /b/ on the other hand went from full retard in early days to not even mildly interesting over the last few years.
Jeffrey Jacques wrote 12/29/2018 at 15:42 point
I get all my internet from ebaum's
Emily Velasco wrote 12/27/2018 at 01:38 point
This is great. Can you explain a little about what's going on here? I've hooked up those flicker leds to an LM386 to listen to them sing, but I didn't realize it could be done with a 555.
Jeffrey Jacques wrote 12/27/2018 at 02:54 point
For the same reasons they make speakers sing, as the leds go through their psuedo-random routine the current they pass / voltage across them fluctuates wildly. This is altering the charge discharge cycle on the 555. One led is fed slightly higher current making it slightly brighter and cycle faster. The hall sensor is a happy accident. I mistook it for a transistor at first (which there is one in there according to the data sheet) hooked up in this unconventional way seemed to work. My best guess is it's floating the ground or something when pulsed. I don't have a scope to check. This is loosely based off the led flasher pg 22 of Forest M Mimms III 555 mini notebook.
Emily Velasco wrote 12/27/2018 at 03:51 point
Thanks for the explanation. A friend of mine was just asking me the other day how he might get an RGB led (the kind with the built-in chip) to sing. I'm going to pass this info along to him because it seems like it should work well for what he wants to do
Jeffrey Jacques wrote 12/27/2018 at 03:25 point
I was thinking of amplifying it but it's already annoying enough as is
Dr. Cockroach wrote 12/27/2018 at 01:33 point
For some reason I just have to have one of those :-D
Jeffrey Jacques wrote 12/27/2018 at 03:29 point
Maybe if I learn how to make badges. I can't imagine hand making more of these.
Dr. Cockroach wrote 12/27/2018 at 09:13 point
Oh, I'll give it a try but it might not be socially acceptable ;-)
Mike Szczys wrote 12/26/2018 at 17:00 point
I hate myself for loving this one :-P
Jan wrote 12/26/2018 at 17:43 point
don't hate yourself Mike. One sees dickbutt, one loves dickbutt.
especially this annoying strange-noises-dickbutt
Jeffrey Jacques wrote 12/26/2018 at 18:12 point
I get that a lot lol
davedarko wrote 12/25/2018 at 10:51 point
oh that's nice on so many levels! Love the battery "connector" and that the LEDs manipulate the 555 :)
Jeffrey Jacques wrote 12/25/2018 at 13:03 point
thanks!
