Img_to_BMP_converter.pyThis script converts all the images in a folder to BMP images for use with a 160 x 128 px TFT LCD display. NOTE: this script assumes that the input images are in the correct 5:4 aspect ratio, and in landscape orientation.x-python - 485.00 bytes - 01/07/2019 at 02:45 |
bmp_array_EXAMPLEExample of output from Image_to_PROGMEM_cpp_array.pybmp_array_example - 3.61 kB - 01/07/2019 at 02:44 |
Image_to_PROGMEM_cpp_array.pyThis script converts image names from a folder of BMP images into a file containing both a char array and the associated PROGMEM declarations w/ corresponding char pointer array and buffer (see bmp_array_EXAMPLE).x-python - 1.86 kB - 01/07/2019 at 02:38 |
song_to_CPP_array.pyThis python script converts a song file (see lucy_in_the_sky_EXAMPLE) of human readable music mechanics to a .sng ( see lucy_in_the_sky_EXAMPLE.sng) file containing an Arduino Tone library CPP int array.x-python - 4.30 kB - 01/07/2019 at 02:38 |
parts_bin_sculpture.inoThis is the full code that runs the sculpture, written in CPP through Arduino IDEx-arduino - 15.66 kB - 01/07/2019 at 02:30 |
Feather_nujabesTranscribed song, Feather by Nujabesfeather_nujabes - 413.00 bytes - 01/07/2019 at 02:27 |
lucy_in_the_sky_EXAMPLE.sngTranscribed song, Lucy In The Sky With Diamonds by The Beatles, translated into int tone array. EXAMPLEsng - 1.31 kB - 01/07/2019 at 02:27 |
Feather_nujabes.sngTranscribed song, Feather by Nujabes, translated into int tone array.sng - 312.00 bytes - 01/07/2019 at 02:27 |
lucy_in_the_sky_EXAMPLETranscribed song, Lucy In The Sky With Diamonds by The Beatles. EXAMPLElucy_in_the_sky_example - 1.17 kB - 01/07/2019 at 02:27 |
lucy_in_the_sky_chorusTranscribed chorus to song, Lucy In The Sky With Diamonds by The Beatleslucy_in_the_sky_chorus - 536.00 bytes - 01/07/2019 at 02:20 |
Maggies_farm.sngTranscribed intro riff, Maggie's Farm cover by RATM, translated into int tone array.sng - 371.00 bytes - 01/07/2019 at 02:20 |
lucy_in_the_sky_chorus.sngTranscribed chorus to song, Lucy In The Sky With Diamonds by The Beatles, translated into int tone array.sng - 424.00 bytes - 01/07/2019 at 02:20 |
Maggies_farmTranscribed intro riff, Maggie's Farm cover by RATM.maggies_farm - 437.00 bytes - 01/07/2019 at 02:20 |
