Project by Multimedia Design students of batch 1701-1 from The One Academy.
i done the doll
also i refind the doll cloth and make the doll neck more shorter
i didn't do the full background the sensor cannot scan the people cause my background too dark .
so i decided change the background just put the curtian for half.
this is my thinkercad that i print it out to my doll
EYE https://www.tinkercad.com/things/9s4yN8MCAw9-swanky-migelo-amberis
TEETH AND MOUTH https://www.tinkercad.com/things/fiqY4vFjXTl-teeth-and-mouth
done all the code for my project.
but unfinish making the doll.
- the head and sensor fix it
- start to build the doll hands, legs and the body
- the head and sensor got problem need to fix i dun know why also my arduino nano is broke need to buy new
- the head and the sensor is done!!!!!!!
- the eyes ball can clip
- Still fix the code need more time to fix
- conform the doll size
- Still code the sensor and the head turn need more time to fix the code.
- Still printing the eyes ball cause the size not correct and the clip keep broke and can't fit in.
-start to code the sensor.
- The doll size to small need make more big
- start to code how the head turn using the arduino.
- i had print some different eyes ball which is fit the head.
- the eyes ball it can clip it and more easy to take out.
- also the mouth and teeth print one by one to stick it.
View all 14 project logs
Alex Hunt
Laio Athos Nevar Fonseca
Geoffroy De Meulemeester
louis.salfati
Yes, delete it Cancel
You are about to report the project "Dynamic Interactivity Final Project", please tell us the reason.
