2445-2465 Fan Collet.jpgServicing 2445/2465 LVPS Fan plus collet removalJPEG Image - 484.36 kB - 08/06/2019 at 00:58 |
calibtools.txtScope calibration tool listingplain - 419.00 bytes - 02/14/2019 at 03:45 |
Tektronix-2465A-B-Oscilloscope-Restoration-Repair.pdfrestoration service guideAdobe Portable Document Format - 777.45 kB - 02/14/2019 at 03:43 |
tek_2465B_2467B.pdfB series service manualsAdobe Portable Document Format - 33.64 MB - 02/14/2019 at 03:43 |
tek_2465a_2467_service.pdfservice manualAdobe Portable Document Format - 37.13 MB - 02/14/2019 at 03:42 |
scope_firmware_2465A-B.zipEEPROM with different options activeZip Archive - 117.42 kB - 02/14/2019 at 03:41 |
Zip Archive - 51.51 kB - 02/14/2019 at 03:37 |
Portable Network Graphics (PNG) - 79.64 kB - 02/14/2019 at 03:37 |
ms-excel - 51.50 kB - 02/14/2019 at 03:36 |
A5 -keeper.JPGWide shot of keeper batt location.JPEG Image - 1.98 MB - 02/14/2019 at 03:30 |
DSCF9123.JPGClose up of Keeper Batt .JPEG Image - 1.99 MB - 02/14/2019 at 03:30 |
Piggyback batt.JPGPiggybacking a Tadiran Keeper batt...note wiring...2 wire install and hot glue to secure batt.JPEG Image - 1.93 MB - 02/14/2019 at 03:29 |
Fan lubed.JPGSimple Fan lube.JPEG Image - 1.85 MB - 02/14/2019 at 03:29 |
DSCF9085.JPGPSU board with old film caps to be replaced, separated from board with Electrolytic capsJPEG Image - 2.07 MB - 02/14/2019 at 03:21 |
leakage corrosion.JPGcorrosion on PCB from Old electrolytic caps on PCB separated from PSU boardJPEG Image - 1.90 MB - 02/14/2019 at 03:19 |
DSCF9096.JPGCorrosion close up after cap removalJPEG Image - 1.95 MB - 02/14/2019 at 03:20 |
DSCF9114.JPGSome New Electrolytic caps installed.JPEG Image - 1.89 MB - 02/14/2019 at 03:28 |
DSCF9104.JPGNew Electrolytic caps installed after PCB cleaned of corrosionJPEG Image - 1.98 MB - 02/14/2019 at 03:20 |
leaky caps.JPGOld leaky , swollen caps removedJPEG Image - 1.88 MB - 02/14/2019 at 03:19 |
DSCF9115.JPGU800 stock -Horiz defl. ICJPEG Image - 1.94 MB - 02/14/2019 at 03:11 |
DSCF9118.JPGCrafting a heatsinkJPEG Image - 1.97 MB - 02/14/2019 at 03:12 |
DSCF9121.JPGPlacing heatsink alum. blockJPEG Image - 1.93 MB - 02/14/2019 at 03:13 |
U800 Hsink mod 3.jpgThermal pasteJPEG Image - 634.38 kB - 02/14/2019 at 03:14 |
U800-Hsink mod.jpgDimensionsJPEG Image - 575.68 kB - 02/14/2019 at 03:15 |
U800_HS_mounted.jpgMounted HsinkJPEG Image - 201.16 kB - 02/14/2019 at 03:16 |
