More Devices
04/11/2019 at 17:18 • 0 commentsThe support of iobroker is really awesome. Support of Paulmann switch controller 500.43 is integrated and will be available with next version of zigbee adapter 0.10.3.
Meanwhile I've tested a Xiaomi Aqara double switch successfully and a RGB LED controller of Paulmann 500.49 that works also fine only the teaching was a little bit tricky.
Since the last weeks two Osram smart+ plugs run without problems.
Integrate Paulmann switch
03/24/2019 at 17:23 • 0 commentsIn the list of supported devices of zigbee adapter I found a switch of Paulmann. After the friendly postman delivered the order I determined that I have ordered the wrong part. The supported switch has the article number 500.44 (dimmable switch) and I have ordered 500.43 (non-dimmable).
But I tried to pair the switch with the zigbee adapter, but not successfully, device was unknown. I tried to solve this problem by contacting the community....
