pisugar_case_pin_cap.STL
cap with gpio opening
Standard Tesselated Geometry - 512.09 kB - 04/06/2019 at 13:31
Download
pisugar_case_button.STL
Button for the battery switch
Standard Tesselated Geometry - 15.90 kB - 04/06/2019 at 13:27
Download
pisugar_nobatt_shell.STL
If you don't have a PiSugar battery, you can use this shell which leaves no space for battery.
Standard Tesselated Geometry - 315.32 kB - 04/06/2019 at 13:27
Download
pisugar_case_common_cap.STL
Common cap for both top and bottom.
Standard Tesselated Geometry - 501.06 kB - 04/06/2019 at 13:27
Download
pisugar_case_shell_xl.STL
A complete case contains a shell, two caps and a button.
Standard Tesselated Geometry - 496.47 kB - 04/06/2019 at 13:27
Download
