OPEN Power
I didn't have enough to buy a Lab Bench PSU... So I made one.
Public Chat
Open Power is about providing Makers, Students, and Hobbyist with a Portable, Versatile Intuitive and Cheap power supply for all their projects.
Prototype 1: Simple and Cheap Constant Voltage/ Constant Current Power Supply variable from 0.6V to 12V with led voltage indication. USB Load sharing powered and Lipo backup. (cost under $3.00)
Prototype 2: A Constant Voltage Constant Current Power Supply 0.6V to 12V In addition to an adjustable Negative Rail. Voltage and current Monitoring Provided by a OLED Display.
Prototype 3: LDO's to Reduce the voltage between 0 and 12V. Both +- Rail Voltage Current and Power will Be displayed on a Full Color LED Display, and oscilloscope/Logic analyzer
The goal of Open Power is not to replace the desktop power supply or oscilloscope but to provide an entry level experience for all.'
We are Committed to keeping OPEN Power Open Source and will release all design file once tested for reliability and safety.
The goals of OPEN Power is to produce 3 final Prototypes. All Power Supplies will have USB Charging of Lithium polymer batteries and a Load Sharing and Uninterruptible power when disconnected.
Prototype 1A:
Simple Constant voltage
Power SupplyVariable from
0.6V to 12V.
Will Include 5V and 3V Rails.
Voltage indicator will be
achieved using comparators and
LED Array.
This was chosen to reduce
cost as much as possible and
keep each board with
components under $2.75.
Status
(COMPLETED)
    BOM (LINK)
Schematic (LINK)
Gerber Files (LINK)
Prototype 1a: Rendering
Prototype 1a: Assembled
Voltage Test
Voltage Test
Load Sharing and Quick disconnect Test
Load Sharing / Uninterruptible Test
Prototype 1B:
Revision 1B The Led arrays are switch
from a linear array to a polar array
around the Voltage and Potentiometer
trimmers have been added to calibrate.
Status
(COMPLETED)
      BOM (LINK)
Schematic (LINK)
Gerber Files (LINK)
Prototype 1B: Rendering
Prototype 1B: Asseembled
Prototype 1C:
Revision 1c will add an additional  Constant Current Knob to allot
user to limit current and see
around what current is being
drawn (10mA Increments).
Status
(Sent to FAB)
       BOM (LINK)
 Schematic (LINK)
 Gerber Files (LINK)
Digikey BOM (10 units)
Prototype 1C: Rendering
Prototype 1C: Routing
Prototype 1C: Inside and out
Prototype 2A:
A Constant Voltage Constant current
Power Supply 0.6V to 12V.
Rail.  Voltage, Current and Power of
thepositive Rail will be displayed on a
compact OLED. Negative Rail Voltage
will also Be displayed as well as the
Battery Voltage.
Status
(Layout Mock-up)
Prototype 2A: Rendering
Prototype 3A:
Utilizes a Boost Inverting IC to get
+-13V and LDO's to Reduce the
Voltage between 0 and 12V.
Both +- Rail  Voltage, Current and
Color 0.96" LED  Display.
Status
(COMPLETED)
      (Some Errors See  Schematic)
        Schematic (LINK)
       Gerber Files (LINK)
            Code (LINK)
Prototype 3A - Render
Prototype 3A: Rendering
Prototype 3A: Assembled
Prototype 3A: Load sharing Test
Prototype 3A: Constant Current Test
Prototype 3B:
Revision 3b will have a DAC Output,
2 Analog input and 4 DIO Pins.
The implementation of a 16-Bit ADC
Will improve the Current Readout
Status
(Sent To the Fab 8/28/2019)
Update - design Errors made and sent
 back to the fab
             Schematic (Link)
Prototype 3B: Rendering
Prototype 3B: Layout
Prototype 3C:
Revision 3c will switch from the
Samd21 to the Samd51 for faster
Processing power and additional IOs.
The LCD will also be upgraded to a
1.3" IPS 240x240 LCD. Since the
circuit is completely analog the MCU
can perform Double duty and
Potentially be used as a Crude
Oscilloscope or Logic Analyzer.
Prototype 3C: Layout Mock-up
Zip Archive - 344.93 kB - 03/29/2020 at 22:13
Download
Zip Archive - 288.02 kB - 03/29/2020 at 22:13
Download
Open Power - Hackaday Prize -720.mp4
Hackaday Prize - Backup Video Submission
MPEG-4 Video - 46.63 MB - 10/01/2019 at 06:24
Download
Open Power - Prototype 3A.zip
Open Power - Prototype 3A - Gerber
Zip Archive - 93.28 kB - 09/25/2019 at 21:34
Download
Open Power - Comparison.pdf
Open Power - Product Line Comparison Vs Competition
Adobe Portable Document Format - 7.11 MB - 09/24/2019 at 00:00
Preview
Download
View all 15 files
  • 2 Ă— MT3608 Boost Converter Modified to be a Sepic Boost.
  • 1 Ă— MIC5225-5.0 5V LDO
  • 2 Ă— LED - 0603 - Yellow LED - 0603 - Yellow
  • 2 Ă— LED - 0603 - Orange LED - 0603 - Orange
  • 3 Ă— LED - 0603 - Red LED - 0603 - Red
View all 45 components
View all 18 project logs
  • 1
    Hackaday Prize Q and A
    i. Is this a unique solution to a particular challenge facing the world today?
    Power Supply and Oscilloscopes are an Invaluable pieces of equipment for Engineers, Hobbyist, and Student.  It allows them to test their circuits under a variety of voltage and current conditions.  The problem is the are bulky, stationary, and expensive.  With release of these cheap Battery power supplies that attach to the breadboards users can make their projects mobile.
    The goal of Open Power is to take it a few steps further.  To integrate Lithium Rechargeable batteries. Quick Disconnect and a Variable Rail (0.6V -12V).  With Iterations capable of Constant Current, Current Monitoring, Digital I/O indicators, Voltage Reads, Crude Oscilloscope and Logic Analyzers.
    All These features with an aim at keeping cost as low as possible.  With our cheapest unit (Less than $2.50 Cost) multiple units can be Purchased and used in multiple projects.  This solves the problem of having to disconnect the circuit from the power supply to start a new project.
    Open Power will NOT replace the bench top power supply or oscilloscope, But it will supplement them and allow greater access to Students, Hobbyist and Makers.
    ii. How thoroughly documented were the design process & design decisions?
    The Design Considerations were based on many factors But it boils down to the 3 Basic Designs with improvement iterations.
    Prototype 1 A was designed to be the cheapest unit available.  Focus is to provide users with a Usb Chargeable unit  with 5 and 3.3v outputs as well as an adjustable rail (0.6V - 12V).  Prototype 1A accomplished this with the brute force method and comprised of 133 Components.  The Fabrication came back and was successfully tested.  Ideas of improvement from the Hackaday community sparked a design iteration that would indicate the Voltage even when the device was powered off.
      (Status: Complete and tested)
    Prototype 1B took those considerations and moved the adjustment knob to the center and arranged the LEDs around the voltage control knob.  This allows the user to see the set voltage even before it is turned on.  This offers a problem that not all Potentiometers are accurate and may not line up with the LEDs. To solve this a potentiometer bridges the voltage knob to set its range. and the Lower feedback resistor will be used to set the 0.6V.  In addition, most of the resistors were switched to resistor arrays which offer a tighter layout and easier reflow.  The Boards height as also reduced from 50mm to 38mm, offering a more compact form Factor.
    Prototype 1C took it one step further and integrated a constant current knob.  This works by measuring the load current at the low end and toggling the feedback pin on and off if it exceeds the threshold. Set by the current knob.  The LEDs surrounding the current knob work off sensing the current and using comparators to show the current in increments of 10mA.
    (Status: Currently being Fabricated).
    Prototype 2A was designed to integrate a negative rail for Op-amp usage.  Since this is for a more advance engineer with more demanding and accurate requirements we decided to implement a OLED display to display the voltage.  At the moment we have only done a layout and have not tested the negative rail.  This circuit is to be entirely analog with the display only providing voltage and current feedback.
    (Status: Layout Designed)
    Prototype 3A was designed to be the most advanced and accurate.  It uses a single IC to boost and invert to +-13V.  This is then past through specialized LDO’s that can be adjusted down to 0V.  This method is costly but provides the best performance of all the prototypes.  Like all models the power is accomplished with complete analog and the Samd21 only does sensing and displays the data on the 0.96in Color TFT.  The reason keeping it analog is stability.  We do not want a code error compromising the output.
    Prototype 3B Was designed to make the correction in 3A.  In addition to the +-Rails  are analog and digital inputs that can be utilized by the user.  2 Analog inputs and 4 Digital inputs.  Analog output DAC can also be used to provide small signals for testing.
    Prototype 3C is the moonshot.  The Screen is upgraded to a 1.3” IPS to provide a larger viewing area.  Because of the larger display a SAMD51 is used to keep a stable refresh rate.  This additional area can be utilized for a Crude Oscilloscope and or Logic analyzer
    iii. How ready is this design be taken to market?
    Prototype 1A, 1B and 3A Have been Designed and are currently being tested.  At the moment Additional safety features are being tested including short Circuit, Overload, etc.  These will be read for market within the next month or so.  These will require sourcing and testing to get the cost down as low as possible.
    One of the biggest challenges with this will be sourcing parts and manufactures to keep the cost low.   Currently the entry model uses 5x LM339 Comparators.  Even in quantities of 5 is less than the cheapest MCU.  But there is a point where there are enough led and comparators that a simple MCU and OLED Makes Sense.  Prototype 2A will address this. Within a 2 month Development Prototype 1C, 2A and 3B will be Ready for market.
    Prototype 3C will require additional Assistance as it will need special libraries for the 1.3” display to provide fast enough refresh rate for real time O-scope.  This would require some Assembly level coding.  But once the code is available to everyone improvements in performance can be made by the User base and implemented in future releases.
    Working with Suppliers, PCB Fab and assembly labs will be a major focus of bringing OPEN Power to the Masses.
    iv. How complete is the project?
    The first few prototype are complete and work as intended.  The rest of the iterations will require fabrication and testing before release to the market.  With each Iteration design flaws and the User interface is refined for a more user friendly experience.
View all instructions
Ale o co chodzi wrote 12/03/2023 at 11:10 point
steper up-down from
0-24V ? AA, 18650 , AAA, 9V etc.
gary_hampson wrote 11/09/2023 at 06:40 point
Just checking in.  Is there any update on the 3C?
deltaterminal01 wrote 09/21/2022 at 17:58 point
Is this project still alive? Doesn't seem like it's been updated for quite some time. I would really like seeing this project fully completed.
minhducpham2009 wrote 03/28/2021 at 01:21 point
What a great project, this is an awesome project.
gary_hampson wrote 03/23/2021 at 20:08 point
Kyra Zimmer wrote 10/07/2020 at 10:42 point
ok srsly, shut up and take my money! please tell me we'll get a 3C soon?
gary_hampson wrote 09/07/2020 at 19:48 point
How's this project going?  I'm really wanting a Version 3C!! :)
randouser1 wrote 07/15/2020 at 00:01 point
Is 3B available to buy (i'll take 2 :) )?  Any progress on 3C?
David H. Bronke wrote 06/11/2020 at 04:09 point
I've been following this project for quite a while now. I hope you're able to get it through the production - I'd love to pick up a few 2, 3A, or 3B boards! Is there anything you need help on?
Andy Geppert wrote 05/23/2020 at 13:19 point
John - this is an awesome project. Very inspiring with your detail/docs/design work quality. How do you create the schematics with the images for the symbols, and how are you rendering the assemblies?
Nicolas Tremblay wrote 05/05/2020 at 21:17 point
Will you be completing this project? I'm waiting on the 3B or 3C to make my own.
acrexp wrote 12/21/2019 at 12:59 point
I'm new at this but have worked around electronic stuff for many years. Now that I have retired I want to dive in a little deeper. This is the best project I have seen hands down.
Like someone else said a DIY kit would be great. Either way sign me up for one when available.
Dan Maloney wrote 09/18/2019 at 15:26 point
I see what you mean about the silk screen. Not bad, but not stunning, which it should be.
Looking forward to more progress on this. Keep up the good work.
John Loeffler wrote 09/18/2019 at 15:34 point
Yes and some of the Pads do not have soldermask in between I was only able to get 1 board of 3 working.  From now on I will be using JLBPCB which came back fantastic.
Dan Maloney wrote 09/18/2019 at 15:38 point
Cool. Just keep the black on white - that's a really good look. Although I did recently see OSHPark offer some cool dark designs.
John Loeffler wrote 09/18/2019 at 15:43 point
I saw that,  A transparent Soldermask that lets you see the copper traces.  This is perfect for finding the errors in my boards.
John Loeffler wrote 09/18/2019 at 15:48 point
And you have to admit that is the perfect logo for this project
Nicolas Tremblay wrote 09/11/2019 at 13:43 point
WOW! I just found your project. Can't wait for it to be market ready. Sign me up for the first kit.
John Loeffler wrote 09/11/2019 at 15:37 point
Thanks,  I defiantly want to keep the Hardware, (Especially the Scope one ) open Source so people can contribute and make it as fast and user friendly as possible.
Robb wrote 09/07/2019 at 19:35 point
It would be cool if one of the models is beginner-friendly to build, using mostly through-hole soldering as opposed to surface-mount.
John Loeffler wrote 09/07/2019 at 23:31 point
Interesting Concept.  I did a little digging and the only component I cannot find would be the boost ic.  This one goes down to 0.6V most only go down to 1.5V.  Made some compromises could be made with a much larger footprint.
John Loeffler wrote 09/08/2019 at 21:50 point
Looking into it further and doing a brief layout that is a definite possibility.  I can use a boost but it will only be able to go down to 1.25V and the leds can only be 1V increments.  But very doable.  The USB will need to be a USB-TYPE B for easy soldering.  The last IC is the Lipo charger, and i don't have any great options right now.
Salamandar wrote 08/27/2019 at 12:53 point
Hi, I'm porting this project to KiCAD as it's much better than Altium on so many levels (ex-altium user here speaking), Linux-friendly and open source.
https://github.com/Salamandar/openpower
John Loeffler wrote 08/27/2019 at 13:04 point
I am already in the process of doing that.  Altium is just much better in terms of CAD and layout.  Once i have verified the boars i will release it on KiCAD
Salamandar wrote 08/27/2019 at 13:47 point
Oh, I've already finished the schematics ^^
Do you want some help on it ? I've some experience on kicad.
John Loeffler wrote 08/27/2019 at 14:14 point
At the moment we are implementing safety circuitry (overload,Short-circit) and then testing.  Our goal is to have a stable and safe platform tested before we release it.  This will be within the next week or so.  We could definitely use your help.  Send me a DM with your Email.
Martin wrote 08/19/2019 at 07:26 point
Why do you use a SEPIC converter for 5V? You power it from a LiIon battery (max. 4,2V) and even disconnect the output while charging from USB. A normal step -up would be sufficient, uses less components and has better efficiency.
John Loeffler wrote 08/19/2019 at 12:49 point
You are absolutely right i will have to change that.  At one pint i was thinking of putting in a Barrel jack for more power options and decided to take it out but didn't change the SEPIC back to a Boost.  Thank you.
Keith Olson wrote 05/03/2019 at 04:34 point
FWIW, Instead of a knob, using 8 jumpers would give you the ability to set 0.1v - 11.9v directly, by using (modified) binary addition.  The major would be set up as 1-2-4-4 (0 - 11) and the minor would be set up as 1-2-2-4 (0 - 9).  For example, a 3.3v setting could be 1100 1100, while a 7.5v could be [1101 1001].  Making one of the major jumpers 8 instead of 4 would allow going up to 16v, and additional major jumpers would allow for even higher voltages.  LED's wouldn't be needed, as the voltage would be visibly displayed.
Does that make sense?
John Loeffler wrote 08/19/2019 at 12:51 point
That does make sense for accuracy.  I do however prefer to have a continuously adjustable rail for testing some circuits.
Jan wrote 11/20/2019 at 06:23 point
That's the most far from user friendly I can think of :) People see a rotary knob and just know what it does.
You have to keep the user of this thing in mind...
Ubi de Feo wrote 04/21/2019 at 07:06 point
Lots of great work going on here :)
I mostly use breadboards with 6 columns per side, rather than 5, and most of these adapters are useless in this case.
Not long ago I was wondering if there'd be a way to make the power rails adaptable to multiple sizes.
Food for thought, I guess ;)
John Loeffler wrote 04/21/2019 at 10:10 point
do you have a picture I could use for reference?
Arya wrote 04/20/2019 at 17:09 point
Consider using 4-resistor arrays, it might allow you to save a bunch of board space and simplify the BOM.
https://p.globalsources.com/IMAGES/PDT/BIG/251/B1064309251.jpg
John Loeffler wrote 04/20/2019 at 19:33 point
Thank you that is exactly what i need
John Loeffler wrote 08/23/2019 at 15:31 point
I have implemented these in my Prototype 1b Design will post Soon
