spool-holder.stl
A cylindrical spool holder that mounts on the aluminium frame
Standard Tesselated Geometry - 48.05 kB - 04/12/2019 at 12:48
Download
lcd-supports.stl
PRUSA iteration4
lcd supports
GNU GPL v3
Josef Průša and contributors
http://www.reprap.org/wiki/Prusa_Mendel
http://prusamendel.org
Standard Tesselated Geometry - 270.36 kB - 04/12/2019 at 12:46
Download
LCD-cover-ORIGINAL-MK3.stl
PRUSA iteration4
LCD cover
GNU GPL v3
Standard Tesselated Geometry - 693.28 kB - 04/12/2019 at 12:45
Download
feet.stl
Plastic feet for the printer to stand on. Required unless you use countersunk bolts to fasten electronics on the base.
Standard Tesselated Geometry - 411.86 kB - 04/12/2019 at 12:44
Download
faceplate.stl
A very awesome faceplate that proudly displays "Rosalind".
The most important part of the printer :-P
Export to amf to preserve the dual colors or set your slicer to print in a different color everything above 2mm
(or just color it yourself :-P)
Standard Tesselated Geometry - 469.33 kB - 04/12/2019 at 12:42
Download
extruder-mount.stl
This file is derived from schlotzz's direct-drive extruder so it's licensed CC-BY-SA 3.0 and not GPL2 as is the rest of Rosalind.
It provides a modified extruder drive mount for mounting the geared wade's extruder with mounting holes that fit the frame exactly. There is also an optional filler block that makes sure the motors don't protrude out of the acrylic enclosure. The rosalind has not been tested with this extruder drive.
Standard Tesselated Geometry - 65.11 kB - 04/12/2019 at 12:40
Download
extruder-drive-direct.stl
Compact direct drive bowden extruder for 1.75mm filament
Licence: CC BY-SA 3.0, http://creativecommons.org/licenses/by-sa/3.0/
Author: Dominik Scholz and contributors
Using MK8 style hobbed pulley 13x8mm from: https://www.reprapsource.com/en/show/6889
visit: http://www.schlotzz.com
Standard Tesselated Geometry - 614.47 kB - 04/12/2019 at 12:39
Download
bowden-extruder.stl
Assembly for mounting an e3d v6 on the Rosalind in bowden configuration
Standard Tesselated Geometry - 2.88 MB - 04/12/2019 at 12:38
Download
angle-fastener.stl
Angles that mount the frame together. Can be replaced with off the shelf metal fasteners
Standard Tesselated Geometry - 774.47 kB - 04/12/2019 at 12:33
Download
x-carriage.stl
The part that moves along the x-axis and carries the extruder
Standard Tesselated Geometry - 5.25 MB - 04/12/2019 at 12:31
Download
x-axis-clamp.stl
The part that mounts the x-axis on the y-axis
Otherwise known as the y-carriage
Standard Tesselated Geometry - 745.06 kB - 04/12/2019 at 12:31
Download
bed-clamps.stl
The parts that clamp the bed frame to the z-axis smooth rods
Standard Tesselated Geometry - 354.48 kB - 04/12/2019 at 12:31
Download
leadscrew-nut-clamp.stl
Leadscrew brass nut pillow block. The part that mounts the bed on the leadscrew so that it moves when the Z-motor turns.
Standard Tesselated Geometry - 73.96 kB - 04/12/2019 at 12:31
Download
motor-mounts.stl
This part mounts the x, y and z motors on the aluminium frame
Standard Tesselated Geometry - 300.19 kB - 04/12/2019 at 12:31
Download
y-axis-clamp.stl
The part that mounts the y-axis rails to the frame of the printer
Standard Tesselated Geometry - 311.25 kB - 04/12/2019 at 12:31
Download
z-axis-clamp.stl
Μounts for the z-axis smooth rods on the frame. Includes mounting space for the z-axis endstop switch
Standard Tesselated Geometry - 187.76 kB - 04/12/2019 at 12:31
Download
