EMG2.6x5.zipThe PCB Gerber file for EMG sensor, size 50x26 (mm)Use this for easy soldering and starting point. This design has been utilized for components available on the market. x-zip-compressed - 36.69 kB - 09/23/2019 at 15:12 |
EMG2.2x2.2.zipThe PCB Gerber file for EMG sensor, size 22x22 (mm)WARNING: This design has not been utilized for components available on the market. x-zip-compressed - 75.08 kB - 09/23/2019 at 15:10 |
EMG3x1.6.zipThe PCB Gerber file for EMG sensor, size 31x16 (mm)WARNING: This design has not been utilized for components available on the market. x-zip-compressed - 71.40 kB - 09/23/2019 at 15:10 |
finger_mechanism.linkage2The Linkage file to design the trajectory of the finger module.XML - Extensible Markup Language - 1.52 kB - 09/23/2019 at 15:09 |
STL KONOSUBA.rarALL THE STL FILES NECESSARY TO CREATE THIS PROSTHESIS.Have fun :D And if you successfully made one, please send me an image! If you have any difficulty while printing and building the prosthesis, also send me a message. RAR Archive - 4.19 MB - 09/23/2019 at 14:50 |
elbow_assembly.3mfThis is a .3mf file with all the parts of the elbow module in place. Use this file to guide you through the assembly of the elbow.WARNING: There are some parts that are used several times, but I only put 1 instance of it in the 3mf file to not causing confusion. 3mf - 1.01 MB - 09/23/2019 at 14:47 |
wrist_assembly_with_handCover.3mfThis is a .3mf file with all the parts of the wrist module in place. Use this file to guide you through the assembly of the wrist.WARNING: There are some parts that are used several times, but I only put 1 instance of it in the 3mf file to not causing confusion. 3mf - 544.72 kB - 09/23/2019 at 14:46 |
Engineering Design 4B Final Report - Nguyen Phuong Duy - s3518550.pdfThe final thesis of this project. I used it as my capstone project at university, and wrote a thorough report for everything I have done, including the design, the literature review, all the schematics and communication protocols, BOM and project management.Adobe Portable Document Format - 5.99 MB - 09/18/2019 at 17:21 |
