images.jpgInspiration for track shocksJPEG Image - 11.23 kB - 07/02/2019 at 00:50 |
20190630_193944.jpgMock up of track mounts. This went through 3 changes before i was happy. Now i cut my first aluminum pieces. Jigsaw and drill press. 1/4" aluminum sheet i had laying around. Should have enough to do other side and base plate of robot.JPEG Image - 3.67 MB - 07/02/2019 at 00:41 |
trackassemblytest_5pack.png5 pack of track pieces. for printing i combined 5 of them. I can print about 30 on my ender 3. But i typically print 20 at a time. In PLAPortable Network Graphics (PNG) - 96.22 kB - 06/25/2019 at 01:56 |
chassis_test2.pngtrack assembly test 2. Modified the brackets and moved the wheels around for better clearance. The blue squares are there so i can print to size A paper and align front and back pieces together. then i can glue to aluminum and cut out the shape with wheel alignment.Portable Network Graphics (PNG) - 338.99 kB - 06/25/2019 at 01:50 |
lowertrack_assembly.pngLower Track Assembly. Spring loaded wheels. Uses standard skateboard bearingsPortable Network Graphics (PNG) - 85.79 kB - 06/25/2019 at 01:47 |
trackchassisotterbracket.pngDrawing layout of track bracket. Blue squares are used for alignment when printing. part is bigger then Size A paper. so this is what i did to help tape both pieces together correctly.Portable Network Graphics (PNG) - 27.95 kB - 06/25/2019 at 01:45 |
SerialStepperController.inoSerial communication code for arduino mega and RAMPS board. I had this hardware laying around. Code is setup for a serial control. Send < x,y > can be -1000 to 1000 steps per second. using 0.9 degree step motor. X is my left and y is my right motor. May modify for 3 more steppers later. as ramps can handle 5 steppersino - 6.46 kB - 06/25/2019 at 01:39 |
mockupTest1.pngtest mockup of track assemblyPortable Network Graphics (PNG) - 566.78 kB - 06/25/2019 at 01:39 |
