Base_Y.stlMoving plate (Y direction)Standard Tesselated Geometry - 290.66 kB - 07/30/2019 at 17:03 |
Base_X_right.stlMoving plate (X direction, right side)Standard Tesselated Geometry - 219.54 kB - 07/30/2019 at 17:03 |
Base_X_left.stlMoving plate (X direction, right side)Standard Tesselated Geometry - 244.09 kB - 07/30/2019 at 17:03 |
Clamp_X.stlPlate to attach the belts intoStandard Tesselated Geometry - 80.39 kB - 07/30/2019 at 17:03 |
pen_holder_lower_part.stlThe lower part of the pen holderStandard Tesselated Geometry - 154.42 kB - 07/26/2019 at 16:36 |
pen_holder_upper_part.stlThe upper part of the pen holderStandard Tesselated Geometry - 111.20 kB - 07/26/2019 at 16:36 |
pulley_holder.stlA holder to keep the pulley and fix it to the baseStandard Tesselated Geometry - 181.65 kB - 07/25/2019 at 17:34 |
motor_holder.stlA holder to fix the motor to the baseStandard Tesselated Geometry - 222.87 kB - 07/25/2019 at 17:34 |
Mona_lisa.gcodeA Gcode example to run with this CNC machinegcode - 44.58 kB - 07/25/2019 at 17:13 |
