z0-z4.pngThe is the schematic that Logic Friday generated when I input the parameters for a [1,4,6,4,1] convolutional filter designed to perform low pass pre-filtering of bitstream data.Portable Network Graphics (PNG) - 34.00 kB - 08/25/2019 at 10:25 |
propadc1.cppThis is the first part of the sigma delta DSP code base for use on a Parallax Propeller or similar microcontroller when performing initial pre-filtering of live data prior to performing any FFT based operations.cpp - 8.86 kB - 08/25/2019 at 09:43 |
