USB
USB connectors are for power only !!!! not for programming !!!!
The ATtiny10 is a high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 1KB ISP flash memory, 32B SRAM, four general purpose I/O lines, 16 general purpose working registers, a 16-bit timer/counter with two PWM channels, internal and external interrupts, programmable watchdog timer with internal oscillator, an internal calibrated oscillator, a 4-channel/8-bit A/D converter, and four software selectable power saving modes. The device operates between 1.8-5.5 volts.
Special features
  • 6x charlieplexed LED controlled with 3GPIO
  • ATtiny10
  • Reset buton
  • single row header
  • 6pin edge programming header USBasp compatible ISP / TPI (not soldered)
  • 0.6mm ENIG GOLD PCB board
POWER options
  • from header
  • CR2032 (holder not included)
  • PCB micro USB
  • PCB USB-C
About PCB USB connector
What's not included
What you can try if it's not working
  • google search
  • TPI is 5V ... switch your USBasp programmer to 5V
  • If your USBasp have no TPI support update firmware (you need another USBasp to upload)
  • check if AVRDUDE support attiny10
Shipped with preloaded sample flashing code
(KITT efect)
#include <avr/io.h>
#include <stdint.h>
int main (void) {
DDRB = 0b0111;         // Equivalent to pinMode
while (1)
led (2,1); //1
led (1,2); //2
led (1,4); //3
led (4,1); //4
led (4,2); //5
led (2,4); //6
led (4,2); //5
led (4,1); //4
led (1,4); //3
led (1,2); //2
void led (char plus, char minus)
 DDRB = 0b0111;         // all input;
 DDRB = plus | minus;
 PORTB = plus;
 PORTB = minus;
  delay (200);
void delay (int millis) {
  for (volatile unsigned int i = 34*millis; i>0; i--);
