• Continuing...
    Michael Möller04/26/2022 at 07:59 0 comments
    Dusting this project off to continue making it more robust and reliable.
    Wear
    The hour hand is held in place by friction, when not nudged along. The plastic-against-plastic wore out pretty quickly, ie it became too loose. So I am hoping that plastic-against-metal will retain the friction fit (longer). Pity, the previous design was all 3D printed parts, making it easy for folks to make their own.
    The next design will use an aluminum pipe for the stationary hour "axis". The hour hand will be still be 3D printed, but now with some clasp so there is a spring effect, or it is possible to add a metal spring/clasp to retain tension. The challenge is to make it elegant. (A more complicated idea is to make the hour hand hollow and put a ballpoint spring inside...)
    Clockoduino
    I need to finish this and use the board (previous log post). Yeah, I said that last year. And the year before that.
  • Working towards a V2
    Michael Möller04/16/2020 at 19:29 0 comments
    I have now designed a PCB which is meant to cover all my clocks, past and future.
    It has an ATMEL328P chip (internal clock) and a RTC chip with crystal and battery backup, a stepper driver,  5V regulator (optional, solderbridge to bypass).  and a 3way button on the edge for setting time. Last but not at least plenty of pin holes for connecting things, stepper, and/or 2 servo, 2 digital IO, one analog, Serial for programming or debugging and the standard ICSP.
    I will use this on the 3 clocks I have designed, and hopefully not discover any flaws, otherwise it is an iteration more.
  • "Minor" problems - V1.b
    Michael Möller02/02/2020 at 16:42 0 comments
    Setting the clock up properly made the clockchip loose its setting, ie produce random time. Was it the stepper making too much electrical noise/power dips? Measuuring it revelaed that the ArduinoPro was a 3,3V version ie the clockchip didnt get the 5v it needed.
    New 5V versions of the ArduinoMiniPro, and some new smaller stepper (the ubiquitous 28BYJ-48) ordered.
    The software acted strange - but the new stepper has gear and thus 2000 steps/revolution so there was (another) overflow in intermediate calculations. Easily fixed by changing the constant 2000 to 2000L ie. the long datatype, and the compiler thus made all integer calculations in long. Still something was not quite matching - how many steps are there for a full rotation?
    Turns out it may be 2048 or 2047.something depending on the precise manuafacture. (google for "48byj-48 gear" and see all the ugly details). I opened my stepper, counted the teeth and was happy to notice mine is exactly 2048 step/revolution.
    Another lucky break is the output shaft is the same size so I just need to drill new mount fittings.
    Early tests with the new steper shows it much smoother/quieter.
    Had to supress for the minute hand to nudge the hour hand every minute (as the stepper resolutin now is so high) so it only does it on even 5 minutes.
    Another visual improvement will be for hour hand not be 100% accuratly positioned, but scaled closer to hour digit so it easier to see what it points to. It is hard to see at 25 to 35 minutes past where it is right in between.
    For now I take the 5V external (USB) supply jumpwire it to Vcc and the Clock-VCC, bypassing the 3.3V regulator, but of course will be done proper on the next one.
    Also need the button mounted for (re)setting the clock and clockchip - and write some code.
  • Final
    Michael Möller01/24/2020 at 16:10 0 comments
    Two videos showing it with a normal clock face and a jumbled clockface
  • Near finished
    Michael Möller01/21/2020 at 19:43 0 comments
    Gallery pictures updated. Here is the back, showing the circuit. Still needs a backplate to set it firm and fit a button for time adjusment (f.ex. summer/winter time)
    Clockchip breakout board, Arduino Nano (no USB, just serial), ULN2001 driver.
  • Progress (2)
    Michael Möller01/19/2020 at 19:08 0 comments
    Electronics (one directly connected UL2001 with Darlington transistors - no more or less) now works.
    Shows the basic principle (and a messy work bench, but such are creative people :-) )
    Various challenges
    When I mounted the drive on a clockface, I noticed the minute hand seems further off than the +/-½ tooth.. Minor problem with the math (truncate vs. rounding) so I do not stop at the nearest tooth but the floor(nearest).
    It seems to be one minute off. Although I can not test it at the moment, I reason it is caused by the stepper motor/circuit/count logic. I simply start with the first coil (of the 4 it has), but it may not be the coil that is aligned with the vertical. One minute is 3⅓ steps. I just need to twist the clock dial or add a start offset in the code.
    Solutions made
    The rounding error was tricky, the calculation became complex as all factors needed taking into account
    Before
        MinuteNxt =
             Jumble[((Minute+2)/5)%12]*Full/12 + (( T>2 )?T-5:T)*Full
                /60;
        HourNxt =
             Jumble[Hour+(Minute>29?1:0)]*Full/12+(Minute>29?-(60-Minute):Minute)
                /12 ;
    After
    #define Round(Num, Den) ((Num)+(Den)/2)/(Den)
    #define Positiv(Val,Wrap) ((Val)<0?((Val)+(Wrap)):(Val))
        MinuteNxt = Positiv( Round(
             ( Jumble[((Minute+2)%60)/5]*5 + ((T>2)?T-5:T) )*Full
                                , 60), Full);
        HourNxt = Positiv( Round(
             ( Jumble[Hour+(Minute>29?1:0)]*60L + (Minute>29?-(60-Minute):Minute) )*Full
                                , 60L*12), Full) ;
    The offset is simply solved by powering on the stepper, jiggling it a little and then manualy turn the hands to the start position (they are only pressfit, so they can be turned while the motor is still)
  • Progress/Outstanding (1)
    Michael Möller12/28/2019 at 18:36 0 comments
    The program has been written and the logic for when to nudge the hour hand has been debugged with plenty of Serial.print(). It is missing the clock stuff, as I still need to find a clockchip in my stuff or buy one.
    A simple circuit with a ULN2001 to drive a simple 4 coil stepper has been created, and yes, the motor moves as it is supposed to.
    Didn't need the the "Stepper" library, I just drive the 4 pins. With only full steps, the program logic is trivial. Turned off when stationary.
    Having some difficulty with the stepper choice, both mechanical and electrical. I have a good stepper but it is large and heavy, but it runs at 5V with 200 steps/revolution. I have a smaller stepper which is better, but has only 50 steps/revolution, which is too coarse. OK, so a simple large gear on the hands being driven by the stepper would do it. I only need 4:1 or better. The lighter stepper wants 24V - but that is for full power, I can drive it at anything 10V-24V, the torque is still more than enough to move the hands. Which means two power rails (5V and something >10V), either two walwarts or a stepdown converter
    Whilst I use a normal Arduino for development work, I want it on a dedicated board at the end.
    I'll go with the heavy 5V motor, to get a "beta"-version constructed. Pro: No gears, simple 5V supply, Con: heavy/bulky behind clockface.
  • Design
    Michael Möller12/23/2019 at 16:02 0 comments
    Basic design objective
    The design is to use a single stepper motor that drives the minute hand. The hour hand is stationary, but can be moved by the minute hand via a small protrusion when they are above each other. The idea is to rotate the minute hand (clockwise) until it has positioned the hour hand, and then move (anticlockwise) back to its correct position. The minute hand will then move normally for a few minutes, and then it will nudge the hour hand forward by the same manuever.
    The hour hand will be positioned exactly like a "normal" hour hand, ie. it will be slightly before, on, and after the correct hour. At half past it will be shifted the large amount to match to the next digit (which will not be adjacent)
    The minute hand does the same; it normally would be close to the hourdigit as on a normal clock., i.e. as it hovers around the "3"-digit it means 13 to 17 minutes past the hour (where the "3" is in some other position)
    Start and reset
    Before applying power one can manually move the hands to 12 o'clock (wherever that number is placed). Future version wil have some small optical sensor to sense that position so restart is fully automtic (assuming the chip has kept time).
    To set the chip time a single button is used to advance the hands until they point correct.
    A few calculations
    A stepper with 200 steps, 1.8°/step, 0.3 minute/step has sufficient resolution so no gearing or halfstep is needed. It can be assumed that it's permamnet magnets will hold position even with the motor turned off. Thus we only need a short current puls to advance it by one step.
    3 short pulses/minute ... might tempt to use a battery, but there are 100's of steps needed to move the hour hand every 5 minute. Quick calculation: need 3*60 for minute advance + 200*(60/5) for nudging hour hand = 2400 steps. A step needs ...ehrm... 200mA for 0.2second? = 40mAmpSecond = 0.11 mAh/step ? That means260mAh/per hour = 6000mAh/24hour plus what the microcontroller needs. Mains it must be. (comments to the calculation welcome)
    ClockFace
    See picture.
  • Credit where credit is due - the origin
    Michael Möller12/23/2019 at 15:31 0 comments
    I am still trying to find the original YouTube that inspired me - to give credit where credit is due. I saw it many years ago (2015?) but the idea stuck in my mind.
    It showed a handrawn clockface, where the hour positions had been mixed up. At the back there was some motor(s) that moved the hands. It was a very thrown-together project. Precisly how the hands moved and pointed to the digits I can not remember.
    What I will "borrow" from that vague memory of the video, is a clockface where the hour position/digits are jumbled, but still evenly spaced around the circle, and of course still be able to work out what time it shows.
    Thats not orginal either
    Got a comment from Dave, which enabled me to find a swiss designer/clockmaker that had a similar idea - at least the clockface part. That webpage gives no indication of if the hands actually move different to an ordinary movement. I think it only is a nice and fancy case.
