1Install the IceStorm toolchain including nextpnr
2Go to the Github link in the sidebar and download the 'blinkencard' project
3Order PCBs, stencil, and components from the BOM from the 'kicad' directory
4Solder it all
53D print the case from the 'case' directory
6Install Micropython with esptool and the ESP-01 programmer
7Connect to the ESP32's AP and upload the files from the 'micropython' directory
8Clone the 's100fpga' project from the sidebar and build with the IceStorm toolchain
make altair
9Copy the resulting altair.bin file to the ESP32 and reboot
The lights should blinken!
10Telnet to the console at the AP's IP address and port 5000
Special commands are:
[CTRL-A] + R to reload the FPGA bitstream from altair.bin and reset the emulation[CTRL-A] + K to halt the terminal emulation and drop to the Micropython shell
