Z8FORTHManual.pdf
From YulBEdwards. Official manual of the Oak Ridge Laboratories FORTH.
Adobe Portable Document Format - 248.57 kB - 01/06/2023 at 22:39
Preview
Download
Z8ForthAssemblerListing.pdf
From YulBEdwards. Official listing of the Oak Ridge Laboratories FORTH.
Adobe Portable Document Format - 324.37 kB - 01/06/2023 at 22:39
Preview
Download
Z8-FORTH-bytes-source.txt
This is the optimised Z8 FORTH source code shown in TM-10463.pdf
written by Oak Ridge Laboratories.
Recreated from OCR text, it may well have typos, but the hex output matches the start of the binary hex dump assembly.
plain - 31.82 kB - 09/01/2022 at 21:25
Download
J021-3-ARC42-U9-PAL10L8-CS1269.jed
Glue logic, a PAL10L8.
jed - 574.00 bytes - 02/07/2022 at 23:11
Download
Z8-FORTH-bytes.z80.hexdump.txt
hex dump created by hex dumping Z8-FORTH-bytes.z80.bin
No long ASCII string visible.
NB: NOT CHECKED OR TESTED YET!
plain - 18.50 kB - 11/04/2021 at 22:50
Download
Binary file created by assembling Z8-FORTH-bytes.z80.txt
octet-stream - 4.00 kB - 11/04/2021 at 22:50
Download
Intel hex file created by assembling Z8-FORTH-bytes.z80.txt
hex - 11.01 kB - 11/04/2021 at 22:44
Download
Z8-FORTH-bytes.z80.lst
Listing created by assembling Z8-FORTH-bytes.z80.txt
lst - 45.54 kB - 11/04/2021 at 22:40
Download
This is the Z8 FORTH ROM dump edited to a series of bytes that can be assembled by most assemblers. I used https://www.asm80.com/ which doesn't assemble Z8 source code but will assemble a series of bytes.
plain - 25.14 kB - 11/04/2021 at 22:33
Download
TM-10463.pdf
Oak Ridge National Laboratory, document TM-10463,
"Optimizing the Zilog Z8 FORTH Microcontroller for Rapid Prototyping"
has a Z8 FORTH presented as an assembler output listing and as a ROM dump. It has OCR text with some errors.
Adobe Portable Document Format - 4.33 MB - 11/04/2021 at 22:30
Preview
Download
rz8_reconstructed_source_code.zip
Source code partially reverse engineered.
Text and BASIC content as ASCII strings.
A few jump tables identified.
Rest converted to disassembly, which may be code or data.
It generates the known-good bytes, so it is a good starting point.
Zip Archive - 56.31 kB - 02/09/2020 at 15:52
Download
Micromint Z8 FORTH user manual.zip
First draft, conversion to html.
4.2 MB as PNG files, but only 16.2 KB in html form with one SVG file.
Alas I don't have a binary image of the FORTH ROM.
Zip Archive - 4.02 MB - 02/08/2020 at 19:31
Download
rz8-basic.txt
BASIC part extracted from binary
plain - 1.67 kB - 02/05/2020 at 01:37
Download
rz8_hexdump.txt
BASIC part
plain - 19.68 kB - 02/05/2020 at 01:36
Download
rz8-dis.txt
The output I am getting so far
text/plain - 57.67 kB - 02/04/2020 at 01:12
Download
z8dis.cpp
Z8 disassembler in C, compiles under Linux
text/x-c++src - 17.30 kB - 02/04/2020 at 01:08
Download
z8_op_table.cpp
#included by z8dis.cpp
x-c++src - 7.85 kB - 02/04/2020 at 01:08
Download
ARC40_RZ8_v4-4_resident_assembler.bin_dis.txt
Based on the hex data bytes
plain - 0 bytes - 02/04/2020 at 01:08
Download
rz8.bin
The rz8 binary that I am using to test the disassembler
octet-stream - 4.00 kB - 02/04/2020 at 01:08
Download
z8dis.c
Z8 disassembler in C source code.
Handy if you wish to analyse the software.
x-csrc - 19.88 kB - 02/03/2020 at 01:28
Download
Byte magazine Z8 article.zip
Design by Steve Ciarcia.
Black and white text and images.
Zip Archive - 4.91 MB - 02/03/2020 at 01:24
Download
Adobe Portable Document Format - 753.68 kB - 02/03/2020 at 01:17
Preview
Download
Z8671_Seven_Chip_Computer.zip
Zilog's own application note
Zip Archive - 313.27 kB - 02/03/2020 at 01:15
Download
Zip Archive - 30.45 kB - 02/03/2020 at 01:13
Download
1981_07_BYTE_06-07_pages-40-49-Build_a_Z8-Based_Control_Computer_with_BASIC-Part_1.pdf
Build a Z8-Based Control Computer with BASIC, Part 1.
Colour and OCR text.
Adobe Portable Document Format - 9.22 MB - 01/28/2020 at 22:27
Preview
Download
Z8_board_documentation.zip
Everything I have related to Z8 boards. Unzip and see:
com/Arcom/catalogue/arcom_cat_ARCbus.htm
com/Arcom/Z8_Monitor
com/Arcom/Z8_Resident_Assembler
com/Arcom/Z8_BASIC_Compiler
com/Zilog/Z8/Z8_MCU.htm (Z6871 wiring to latch and RAM)
com/Zilog/Z8/BASIC_debug/Z8671_BASIC_debug.htm
application/zip - 16.53 MB - 01/19/2020 at 16:02
Download
