vJoySetup.zipI may have crossed a line offer someone else's code. If so please let me know. This setup program will create a virtual joystick on your PC. This allows the python code to send joystick movementsx-zip-compressed - 10.39 MB - 01/25/2020 at 21:44 |
pyvjoy_python_lib.zipThis zip contains the pyvoy joy directory that is in my C:\Python27\Lib\site-packages directory. I had to make some minor changes to make it work. It is offered here in the hope it may help others work out there problemsx-zip-compressed - 86.89 kB - 01/25/2020 at 21:44 |
pyvjoy_serial_mapper_v2.pyProvides the interface between incomming serial data and a virtual joystick device created by vJoyplain - 2.38 kB - 01/25/2020 at 21:40 |
PS2X_esp_lib.zipThe modified PS2X library to work with ESP8266. This was a hack and could do with a clean up. I have limited skills here so I just made it work for ESP8266x-zip-compressed - 5.42 kB - 01/25/2020 at 21:25 |
wifi_ws_server_AP_PS2__v6.inoESP8266 code that runs on the WEMOS that is connect to a PC or droid or any remote device that needs to be controlled.ino - 6.83 kB - 01/25/2020 at 21:22 |
wifi_ws_client_EP_PS2_v6.inoESP8266 code that runs on the WEMOS wired to the PS2x Controller. Requires a modified version of PS2X_lib - PS2X_esp_lib to work with the ESP8266ino - 8.56 kB - 01/25/2020 at 21:20 |
