Phabricator on raspberry pi
Back to overview
how to setup Phabricator on a raspberry pi 3B+ with a RAID on usb sticks to store the data somewhere else than on the SD card
Vincent Mercier wrote 11/07/2020 at 21:32 point
There is no step here to show how the Phabricator's daemons could be launched at boot up instead of launching them manually. The easy way I found is to sdd this line on the rpi's /etc/rc.local:
sudo /var/www/phabFolder/phabricator/bin/phd start
Nathann wrote 11/10/2020 at 08:04 point
i personnally just added a cron with
@reboot php /var/www/phabricator/bin/phd start
i should update this install process i improved tid and bits.
Vincent Mercier wrote 10/30/2020 at 18:07 point
The phabricator.conf file has an error, the first line should be read as
"<virtualhost *:80>"
Nathann wrote 03/11/2021 at 14:53 point
i fixed it. thank
