firmware(BL).bin
Firmware for the HSL E5-001 printer (No filament sensor, BL Touch enabled)
octet-stream - 193.46 kB - 09/01/2020 at 17:17
Download
Configuration(BL).h
Configuration.h for the HSL E5-001 printer (No filament sensor, BL Touch enabled)
h - 599.00 bytes - 09/01/2020 at 17:17
Download
firmware.bin
Firmware for the HSL E5-001 printer (No filament sensor, no BL Touch)
octet-stream - 179.42 kB - 06/20/2020 at 01:17
Download
Configuration.h
Configuration.h for the HSL E5-001 printer (No filament sensor, no BL Touch)
h - 421.00 bytes - 06/20/2020 at 01:18
Download
Marlin-1.1.x(1).zip
Marlin 1.1.9 for use with stock Creality V1.1.9 board
x-zip-compressed - 4.78 MB - 06/20/2020 at 08:11
Download
teachingtechender5v2.zip
Teaching Tech Ender 5 config files for use with Creality V1.1.9 board
x-zip-compressed - 50.27 kB - 06/20/2020 at 08:12
Download
TH3D EZBoard Documentation.pdf
TH3D EZBoard installation manual.
Adobe Portable Document Format - 1.32 MB - 06/19/2020 at 22:09
Preview
Download
Part_Cooling_Fan_Duct_V1.4_Upper_Half.stl
Creality Endehttps://cdn.hackaday.io/files/1716997345970016/Part_Cooling_Fan_Duct_V1.4_Upper_Half.stlr 5 Part Cooling Fan Duct (Upper Half) by ShaunTheBaa
https://www.thingiverse.com/thing:4262259
Standard Tesselated Geometry - 175.96 kB - 09/01/2020 at 17:20
Download
Part_Cooling_Fan_Duct_V1.4_Lower_Half.stl
Creality Ender 5 Part Cooling Fan Duct (Lower Half) by ShaunTheBaa
Standard Tesselated Geometry - 184.46 kB - 09/01/2020 at 17:18
Download
back_left_cover.stl
Ender 5 Y-Axis belt cover (Rear Left side) by D_jespersen
https://www.thingiverse.com/thing:3412007
Standard Tesselated Geometry - 1.96 MB - 05/26/2020 at 22:21
Download
front_right_cover.stl
Ender 5 Y-Axis belt cover (Front Right side) by D_jespersen
Standard Tesselated Geometry - 1.88 MB - 05/26/2020 at 22:20
Download
front_left_cover.stl
Ender 5 Y-Axis belt cover (Front Left side) by D_jespersen
Standard Tesselated Geometry - 1.88 MB - 05/26/2020 at 22:18
Download
Arm_RH_Remix1.stl
Ender 5 Bed Supports (Right side) by BoothyBoothy
https://www.thingiverse.com/thing:3661405
Standard Tesselated Geometry - 724.40 kB - 05/26/2020 at 22:17
Download
Arm_LH_Remix1.stl
Ender 5 Bed Supports (Left side) by BoothyBoothy
Standard Tesselated Geometry - 708.38 kB - 05/26/2020 at 22:16
Download
Back_Plate_Remix1.stl
Ender 5 Bed Support Back Plates (both sides) by BoothyBoothy
Standard Tesselated Geometry - 1.07 MB - 05/26/2020 at 22:22
Download
X_Axis_Gantry_Cover_right.stl
Ender 5 X-Axis belt cover (Right side) by D_jespersen
https://www.thingiverse.com/thing:3465579/
Standard Tesselated Geometry - 454.48 kB - 05/17/2020 at 06:02
Download
X_Axis_Gantry_Cover_Left.stl
Ender 5 X-Axis belt cover (Left side) by D_jespersen
Standard Tesselated Geometry - 365.90 kB - 05/17/2020 at 06:02
Download
Standard Tesselated Geometry - 1.03 MB - 05/17/2020 at 06:00
Download
Standard Tesselated Geometry - 160.73 kB - 05/17/2020 at 05:59
Download
