Embeddio SNAP Boards were made to become the future standard in order to assist Software Developers and Hardware Designers - All In One Snap!
The I2C bus is used for communication between master(s) and slave device(s) using only 2 wires. Embeddio SNAP Boards can be snapped on top of each other to simultaneously develop your software.
SNAP Boards are designed such that it actually provides the user access to pins (e.g. SDA and SCL) using the stackable Arduino pin headers. This means you can simply plug in your wires from your logic analyzer or TTL serial cable which makes debugging even easier now that these pins are easily accessible.
Done developing your software? Snap the module, with castellations and a small footprint, out of the SNAP Board and easily design your own custom circuit board (footprints are available). Designing PCB's was never so easy!
Last but not least, these boards come in a variety of different colors!
