Shredder.FCStdStand in for a aluminum soda can shredder. I'm trying to keep this to parts that anyone, anywhere can source themselves. In this case, I used the dimensions for commonly available leaf spring steel. Which is hardened and tempered. 80mm wide by 7mm thick. It'll need to be cut to 100mm to 107mm and welded together. However, the gears and a method for shredding the soda cans are both something I'm still trying to figure out.application/x-zip-compressed - 60.08 kB - 06/02/2020 at 06:06 |
2020_CornerBracket.FCStdThe model for the 2020 Corner Bracket. Can be exported as an STL and printed. Then, with the Aluminum Recycling Micro Factory, cast with PLA.x-zip-compressed - 31.66 kB - 06/02/2020 at 06:05 |
Frame.FCStdUpdated with 2020 90 Degree Angle Brackets, additional reinforcing corner sheets and the T-slots and machine screws to be added later.application/x-zip-compressed - 224.07 kB - 06/02/2020 at 05:49 |
Bill of Materials.odsBill of materials so far. I live in the arctic, so shipping prices are pretty high.spreadsheet - 14.08 kB - 05/29/2020 at 03:50 |
