dronecoria_6mm_v0_6_4.AIDronecoria Frame Version 6Adobe Illustrator files to send to the laser cut. postscript - 454.71 kB - 05/29/2020 at 18:15 |
SeedShutter.stlShutter of the bottle to open/close and adjust the seed flow.STL files to 3D print Standard Tesselated Geometry - 8.40 MB - 05/29/2020 at 18:18 |
SeedDisperser.stlDisperser to spread the seedsSTL files to 3D print Standard Tesselated Geometry - 4.37 MB - 05/29/2020 at 18:18 |
dronecoria_6mm_v0_6_4.dxfDronecoria Frame Version 6DXF files AutoCAD DXF - 5.48 MB - 05/29/2020 at 18:14 |
