V005.zipThe network driver code - takes the raw input from the array and converts it to ASCII hex for the Java to read. Also has a "Log" version just for logging data to a file instead of streaming into a fifo.You will also have to increase the default MTU (maximum transmission unit), which is 1500 or something by default. Meaning packets have to be less than 1500 bytes or they'll be dropped by the network driver or something. The array sends 2400 byte packets, so you have to increase this, I went up to 4000. x-zip-compressed - 1.78 MB - 06/02/2020 at 01:46 |
C009_MultiImages.zipProcessing sketch to do real-time imaging. Requires the network driver to be running at the time as well to work, OR, a logfile to be piped into the FIFO.You'll first have to make a fifo using mkfifo (I called mine /home/john/pipe, it's hadcoded near the end of the file). If you just run a file cat Logfile.log > /home/john/pipe while this is running this should work x-zip-compressed - 97.71 kB - 06/02/2020 at 01:38 |
PAR_03_ALLBOARDS.zipthe FPGA firmwarex-zip-compressed - 3.15 MB - 05/29/2020 at 23:33 |
Reflection.mp4Video showing acoustic reflection off of a piece of acrylicMPEG-4 Video - 34.65 MB - 05/29/2020 at 23:19 |
odds_medium_moving.aviMoving speaker in front of the arrayAudio Video Interleave (AVI) - 17.69 MB - 05/29/2020 at 23:17 |
evens_moving_2.aviMoving speaker in front of the arrayAudio Video Interleave (AVI) - 4.16 MB - 05/29/2020 at 23:16 |
V004_main.mMATLAB code for doing post-processing on data from the arraym - 36.52 kB - 05/29/2020 at 23:15 |
JPEG Image - 7.70 MB - 05/29/2020 at 23:15 |
MPEG-4 Video - 12.20 MB - 05/29/2020 at 23:15 |
JPEG Image - 4.14 MB - 05/29/2020 at 23:14 |
