Elegoo balance hat.stlA sort of upturned sombrero type thing which round things can yammer about in.Adds mass high up which increases stability and reduces period of oscillation. Standard Tesselated Geometry - 889.24 kB - 06/04/2020 at 19:22 |
Elegoo balance arms.stlWhy did it have only 1 arm? A pair of arms is clearly better. This makes it possible to get back up from either a backward or forward fall. In fact getting up is easier as 2 arms are more balanced - and I cheated a bit by extending them slightly to lessen the angle of tilt when leaning on one.Standard Tesselated Geometry - 249.59 kB - 06/04/2020 at 19:22 |
