Open Exosuit for Differently Abled
This is a lower limb exoskeleton developed to aid patients with walking disabilities in their therapies and to perform simple tasks.
Public Chat
Robotics for rehabilitation treatment is an emerging field that is expected to grow as a solution to automate training.This device addresses the lack of assistive devices for people with walking difficulties around the globe. A major problem they suffer is their dependency on a caretaker for basic tasks such as toiletries and fetching water or food for themselves. This is also common among people with paraplegia ,hemiplegia and cerebral palsy. As post-treatment care and constant help cost a lot, this is where we decided to focus our energies on.
Robotic rehabilitation can replace the physical training effort of a therapist, allowing more intensive repetitive motions and delivering therapy at a reasonable cost, assess quantitatively the level of motor recovery by measuring force and movement patterns. We have found that early rehabilitation in people with cerebral palsy will help in regaining their walking capabilities.
GOAL :
 Our aim is to provide better rehabilitation and assistive technology solution for people who are facing lower limb mobility issues.
Pain Statement trying to solve
 Potential users of our product are people with walking disabilities  The device would help gain independence from caretakers in doing simple daily activities of life while several secondary problems arising from wheelchair use could be solved.
Our device addresses the lack of assistive devices and rehabilitation devices for people with lower limb disability. A major problem these patients suffer is their dependency on a caretaker for basic tasks such as toiletries and fetching water or food for themselves. Our product has been specifically designed to tackle these daily struggles within a work-space or home-space.
Treatment cost
It is reported that the average lifetime cost per person with Cerebral Palsy is estimated around $1.5 million i.e. around $800,000 for indirect medical costs, $100,000 for direct medical costs and around $100,000 for direct non-medical costs, according to Morbidity and Mortality Weekly Report.  It should be noted that while some people may be able to afford the treatment costs for a lifetime, many people couldn’t even afford the initial treatment costs.
Details
There are two parts in this project: 1 ) walker and 2) Exosuit system.
First, the walker has to be switched on and then the O-LED screen in the walker shows the menu to sit, stand, walk. The buttons can be used to select between different menus and joystick in the walker can be used to send signals for walking to Exosuit system. The entire system is communicated with paired Bluetooth.
You can refer to this block diagram:
Block diagram of entire system
Part 1
Walker Unit
The Walker unit in this project uses an o-led screen for display, There are four buttons one for switching on the entire system other three are for selection of menu like walking, standing and sitting. Also there is an joystick connected to move forward and stop.
Also there is a Arduino Nano and a Bluetooth module to send signal to Exosuit system.
Connecting OLED with Arduino
Oled screen can be connected and we can display images. The Bmp file can be converted into Hex file and can be used in our code. You can refer this tutorial for understanding more about conversion of bmp file.
Images
Walker
Walker
Connection
Connect the components as shown in the schematic diagram
Arduino Nano OLED
GND ---------------------- GND
5V ---------------------- 5V
A5 ---------------------- SCL
A4 ---------------------- SDA
Arduino Nano HC-05( Bluetooth)
Rx ---------------------- Tx
Tx ---------------------- Rx
Arduino Nano Joystick module
A1 ---------------------- X pin
Arduino Nano Button
Pin2 ---------------------- Button 1
Pin 3 ---------------------- Button 2
Pin 4 ---------------------- Button 3
Pin 5 ---------------------- Button 4
Working (Walker)
The walker was made by cutting the front portion of normal walker and adding wheels in the two front legs.Holes for were made using drill machine. Grips were also added.
The Walker unit in this project uses an oled screen for display, There are four buttons one for switching on the entire system other three are for selection of menu like walking, standing and sitting. Also there is an joystick connected to move forward and stop.
walker working video
Part 2
Exosuit System
Working
When data from the walker is provided to the exosuit the motors rotates and each motor is connected to one mechanical leg of exosuit. During one rotation the exosuit is designed to take one step.
The mechanical legs can be attached to our legs with straps and belts
Exosuit system
Exosuit system
Connection
Make the connection as shown in the schematic diagram
Arduino...
unik xo.CATProduct
Assembly of complete exosuit
catproduct - 110.46 kB - 06/24/2020 at 18:43
Download
catpart - 76.39 kB - 06/24/2020 at 18:43
Download
motor casing.CATPart
exosuit part CAD
catpart - 708.07 kB - 06/24/2020 at 18:43
Download
left foot base.CATPart
exosuit part CAD
catpart - 177.61 kB - 06/24/2020 at 18:43
Download
right foot base.CATPart
exosuit part CAD
catpart - 177.96 kB - 06/24/2020 at 18:43
Download
View all 19 files
  • 1 × Arduino UNO & Genuino UNO Microcontroller
  • 1 × Onion Corporation OLED Expansion OLED
  • 1 × Battery protective system
  • 1 × Analog joystick (Generic)
  • 5 × SparkFun Big Red Dome Button
View all 11 components
View all 7 project logs
  • 1
    Download All materials provided
    The complete 3D CAD designs, circuit diagrams and arduino codes ( since we used Arduino) are provided here
  • 2
    Mechanical Structure fabrication and Assembly
    Refer the mechanical designs  provided and fabricate according to the dimensions provided, we used Iron sheets for fabrication. We are also working on Aluminum sheets which are light weight and strong .
    Mechanical Design
    The detailed design files are attached with this tutorial as CAD file.
    Fig 1. Diagram marking various parts of the exoskelton.
    Parts Description
    Parts Description
    Also refer to the below images to make the mechanical structure to be connected.
    The measurements and complete details are mentioned in the diagrams you can follow it and attach it together as seen in Fig 1.
    You can use  normal manufacturing techniques to replicate this design. You can also refer the Cad file to assemble all parts .
  • 3
    Electronics and Motors
    The electronics components in this project is available easily through online shopping sites. Gather all components, the components used are provided in the components section.
    We are working on the building a PCB version so that it will help you to rebuild this project really fast and accurately .
View all 6 instructions
barkertiedemannson4 wrote 12/17/2023 at 12:54 point
Your endeavor is incredible. This endeavor has given me a lot to learn. I'd want to distribute it to the  Gelato Pique coupon codes  team so they can read it and apply something fresh to our ongoing efforts.
mathewikku96 wrote 09/06/2020 at 09:30 point
Wow, Amazing can this be used as an assitive device too??
athulsunny008 wrote 08/20/2020 at 14:00 point
First of all this is a great project.  Which material  are you using??
Alex M Sunny wrote 08/22/2020 at 14:58 point
thank you...right now we are using iron alloy but we are planning to use aluminium sheets to reduce weight.
sruthimolchacko1995 wrote 06/26/2020 at 18:04 point
This is truly above and beyond.guys really hit it.
Robin Kanattu Thomas wrote 06/27/2020 at 15:32 point
Thanks
aniyathomas149 wrote 06/26/2020 at 13:19 point
Outstanding work👍👍👍
Alex M Sunny wrote 06/26/2020 at 15:34 point
Thank you
Thanks
John wrote 06/26/2020 at 12:39 point
Good work
Thanks
