We interviewed people who built, lived in CalEarth houses.
The aim is to get to know their pain points - if there are any, and learn about improvements that they wish to have in the CalEarth houses.
Davide Frasca
MSc in Sustainable architecture, founder of Vide Terra, wants to make sustainable construction more reachable, Torino, Italy.
Factors of CalEarth house that you like?
- Shape is non-cube! circle is good.
- Material - one material you can built everything.
- Sustainable
Pain-points to build a CalEarth house?
- Labor intensive,
- Cost for labor,
- Weather is important and its limitation for the construction.
- Problem with rain because of not having a roof. It needs special care about the plaster.
Changes needed & can be developed for CalEarth construction?
- Compass - can be improved.
- Ability to mix soil and control humidity -It takes time and labor
- Any Mechanism to fill the bag - anything that can help the worker to facilitate the filling of the bag can help.
- Labor is expensive - the factor can be a big part of the cost of the house.
Learn more here
Paul Kreiner
Sustainable builder wants to innovate new techniques, Germany & Vienna
- Working with earth - connecting with the material
- Easiness of the construction, Has higher tolerance
- Aesthetics of the dome structure - standing inside is a structure is a special feeling
- Soil + Clay composition (sometimes you need a lot of external material)
- Labor intensive - if its not a workshop its really hard to find a labor
- Tools are not available for the build process as they are manufactured for the flat houses
Changes needed / can be developed for CalEarth construction?
- Burlup bags - organic
- Would focus more on the vault structure - it is easy to use furniture and build it everywhere,
- Plastering is a problem.
Learn more here
Nico- New Ruins
Sustainable farmer, landowner wants to create sustainable eco-tourism, Oaxaca, Mexico
- Organic Appearance - really attractive
- Sustainable living
- Low Cost
- Earthquake Resistance
- Self thought, learnt it from Digital files and has built 2 houses and has them for 8 years. Aspiring to built 5 more houses.
- Limited to one story
- The material has to be brought to site
- Physical effort, intensive labor work
- Stitches the ends of earth bags using a needle to keep them closed.
- Mini crane/ system to move material could be good.
- Development in compass.
- Mixer - get an old cement mixer to mix the composite on site.
- Uses two lines of metal wire in between layers for more stability.
Learn more here
Omid Rahmani
Afghan architect, wants to build schools in Afghanistan. Mashhad(Iran) and Herat (Afghanistan)
- The types of materials used are abundant, earth, clay, soil
- Fast to build after earthquakes
- Can build in afghanistan to make schools and emergency shelters
- Abnormal appearance, not accepted/welcomed/trusted by some people
- Finding specialised labour is hard in Iran
- Hard to get approvals for construction
- Get people to engage with them/interact with them to become more comfortable with the style.
- Very good market for villa’s - appeals to new rich/ youth, luxury-chic style
- Low income market is present in Afghanistan not in Iran.
Learn more here
Ashley Phillips
Young couple, building their own home , enjoy sustainable living. Willow springs, Missouri, United States
- Stable and protected from storms, gives feeling of safety and comfort
- Cooling works nice at night, you sleep really good
- Cost effective
- Sustainable, fits well into our lifestyle of living with nature
- Safety at height, as the construction height increases is hard to balance on the top layers.
- Outside Build; Extreme weather, rain, cold, keeping building protected during the storm. The land freezes in winter making it impossible to build.
- Slow build progress
- Trying an new weather proofing material on the outside.
- Have integrated bar table style furniture in-between the build layers to reduce cost and make integrated furniture.
- Have integrated chains in the layers to be able to practice different hobbies and hang lighting.
- Need a lot of improvement in the way the material is passed from below to above- may be a pulley?
Learn more here
