A more precise clock with RTC
09/14/2022 at 19:07 • 0 commentsThis was an experiment to make an easy, no external components, simple clock.
But of course they are dedicated chips when you want to have precise time.
One of them is the popular DS3231, also not the cheapest if you add in a PCB, you can find it for around 3 USD in Aliexpress or eBay.The DS3231 is a low-cost, extremely accurate I2C real-time clock (RTC) with an integrated temperature- compensated crystal oscillator (TCXO) and crystal.
Cale-idf adds also color epaper classes
09/15/2020 at 10:11 • 0 commentsE-paper component driver for the ESP-IDF framework and compatible with ESP32 / ESP32S2 can be found in this repository:
https://github.com/martinberlin/cale-idf
Codenamed Cal e-pe-de for the initials of E-Paper Display this is basically all what I’ve been doing the last weeks. Learning more about C++ object oriented coding and preparing a class that can be used to send graphic Buffers to different epaper displays. In order to do that I’m documenting on the go and building at the same time CALE-IDF that is our Firmware version for CALE.es but this time built on top of the Espressif IoT Development Framework (IDF)
The mission of this new component is to have a similar library for ESP-IDF that is easier to understand. If possible strictly meeting these requirements:
- Extendable
- Maintainable
- Object-Oriented Programming with human-readable code and function names
- Easy to add a new Epaper display drivers
- Easy to implement and send stuff to your Epaper displays
- Human-understandable
- Well documented
- ESP-IDF only (No Arduino classes)
Please find here the Wiki with the models that are already supported in the component:
Wrist esp32 epaper watch get's a housing and updated C++
07/20/2020 at 14:46 • 0 commentsAs a preamble, due that this is very small, I used a tinypico.com ESP32. I took the steps done by Unexpected maker to turn off the Dotstar led so it consumes as less as possible in deepsleep (My measurement 0.08 mA)
With a Lipo battery of 80 mA tt has been working since Friday 11:30 am (146 hrs aprox.)
If my maths are not wrong 80/146 is approx. 0.54 mA per hour consumption. Updating every 4 mins the epaper and WiFi sync only once per day less than 2 secs online using esp32 tinypico.https://www.thingiverse.com/thing:4546700
Smallest epaper option that I used is an Heltec 1.54 inches (200x200) Please note that at the moment I'm not measuring battery level, when it's over it will simply not update anymore, and you may see small droplets of black in the epaper (Current is not enough to turn it full black I guess) This is how it looked when it stopped:
Repository is the same just in branch refactor/oop:
https://github.com/martinberlin/cale-idf/tree/refactor/oop/main
C++ source: demo-sleep-clock-v2.cpp
Happy builds! -
Wrist digital Epaper watch
07/12/2020 at 08:09 • 0 commentsWhile on holidays I found in the studio of my father a small 1.54 inches epaper
Why not to add a tinyPICO esp32 as a controller and make a real epaper clock using a customized version of the clock firmware?
Me thinks is a cool idea and will be a cheap make, with the exception of the esp32 that is about 22 dollars. But is worth it!
The difference with cheap boards makes it a good choice:
- Deepsleep consumption with dotstar led Turned off is 0.08 mA
- Has 4 MB spiram (pseudo static ram)
- It’s super small!
Additionally we will need a:
- Small battery
- 3D printed case for the watch body
- Watch strap
no buttons for now! It will be a button less digital clock
A small preview just with the epaper on my wrist :)
Do you like the idea? Would you walk with an esp32 in deepsleep mode on your wrist?
New 7.5 inches build
07/09/2020 at 06:57 • 0 commentsThis 800*480 epaper is sold by Waveshare but the display's brand is Good display. Never understood 100% how it is between those two but my thoughts are that waveshare adds electronics on top. Like the SPI interface. Or in some models even a PCB ready for an esp32. But the epapers for makers since ages are mostly from http://www.good-display.com
This new model I made for my father that is the one who really knows about electronics and usually compiles and tests some of my firmwares. He added some custom modifications in this branch:
https://github.com/martinberlin/cale-idf/tree/carlos/7.5-digital
Battery is 5000mA and esp32 used is a http://tinyPICO.com (0.08 mA/h deepsleep consumption w/dotstar turned off)
We added a microseconds int64 correction to compensate boot time. Doing so I realized the Boot-Time correction so the clock is more precise is about 0.3 seconds. That means when you power on the esp32 it takes aprox. 0.3 seconds to arrive to the startTime first measurement. It does his update, with internet sync or not depending on the hour, and at the end measures endTime. So it discounts that time to the next sleep round plus our correction time that we called microsBootPrediction. In other words the program runtime the is discounted from the minutes sleep round.
That number is discounted from the N minutes Deepsleep you select. As is given in microseconds calculation is done in this function:
void deepsleep(){ esp_deep_sleep(1000000LL * 60 * sleepMinutes - microsCorrection + microsBootPrediction); // + microsBootPrediction }
CalEPD is the epaper component behind this clock
07/04/2020 at 20:37 • 0 commentscale-idf Wiki is where CalEPD component is being developed but also where each epaper module testing is being documented.
You can use this module to drive your ESP-IDF epaper project too independently from this project. CalEPD has it's own repository so you can use it as a git submodule for your ESP-IDF firmware.
If your epaper class is not there just add an issue in the repository.
