My GUID number.pngThis is my GUID. If yours is the same then I'll send you the files you need to edit it's parameters.Portable Network Graphics (PNG) - 23.69 kB - 09/16/2020 at 15:38 |
DMOC445.ccsAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.ccs - 123.18 kB - 09/16/2020 at 15:38 |
BAS Partitur Format - 4.14 kB - 09/16/2020 at 15:38 |
BAS Partitur Format - 4.09 kB - 09/16/2020 at 15:38 |
ccShell-3.1.8.01_setup.zipMost recent ccShell program.Zip Archive - 4.94 MB - 09/16/2020 at 15:38 |
BAS Partitur Format - 4.15 kB - 09/16/2020 at 15:38 |
FRC-03FB-3022-004-0000.ccsAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.ccs - 121.65 kB - 09/16/2020 at 15:38 |
CCShell2.0.zipOld ccShell programZip Archive - 7.62 MB - 09/16/2020 at 15:38 |
Zip Archive - 11.47 kB - 09/16/2020 at 15:38 |
ccShell program.zipSome other versions of the ccShell programZip Archive - 20.44 MB - 09/16/2020 at 15:37 |
ccshell.zipSome other versions of the ccShell programZip Archive - 20.44 MB - 09/16/2020 at 15:36 |
SFT-10-1631-000_2008_03_10.ccsAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.ccs - 80.50 kB - 09/16/2020 at 15:36 |
SFT-10-1631-000_2009_12_14_withIsUVW.ccsAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.ccs - 85.59 kB - 09/16/2020 at 15:36 |
SFT-10-1631-000_2008_03_10 EE2PSHighBatIsMax390.ccsAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.ccs - 80.50 kB - 09/16/2020 at 15:36 |
DMOC445_144V_2010-04-30.zipAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.Zip Archive - 805.00 bytes - 09/16/2020 at 15:36 |
DMOC445_156V_2010-04-30.zipAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.Zip Archive - 1.19 kB - 09/16/2020 at 15:36 |
BAS Partitur Format - 1.81 kB - 09/16/2020 at 15:36 |
DMOC445_168V_2010-04-30.zipAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.Zip Archive - 1.19 kB - 09/16/2020 at 15:36 |
Zip Archive - 12.41 kB - 09/16/2020 at 15:36 |
DMOC445_192V_2010-04-30.zipAll kinds of different .ccs files. It won't work for your controller unless the GUID number matches. You'll brick your controller if it doesn't.Zip Archive - 1.19 kB - 09/16/2020 at 15:36 |
JPEG Image - 479.77 kB - 09/16/2020 at 15:36 |
JPEG Image - 399.69 kB - 09/16/2020 at 15:36 |
Adobe Portable Document Format - 2.11 MB - 09/16/2020 at 15:35 |
Adobe Portable Document Format - 182.95 kB - 09/16/2020 at 15:35 |
SKF Bearing Encoder for Insight.pdfThis is the encoder used in the AC24ls motorAdobe Portable Document Format - 146.76 kB - 09/16/2020 at 15:35 |
hondainsight.stl1st gen general shapeStandard Tesselated Geometry - 8.63 MB - 09/16/2020 at 15:35 |
Adobe Portable Document Format - 5.14 MB - 09/16/2020 at 15:34 |
Adobe Portable Document Format - 12.46 MB - 09/16/2020 at 15:33 |
Adobe Portable Document Format - 7.39 MB - 09/16/2020 at 15:33 |
Adobe Portable Document Format - 527.26 kB - 09/16/2020 at 15:33 |
