Minor updates
02/09/2023 at 09:24 • 0 commentsThe hardware and software works good enough for my needs, so only small updates:
- Added combined echo and CR support for terminal mode,
- Replaced the python3 romEmuFeed program with a newer version with better argument handling and made the tty port an argument too.
Arduino firmware and Python upload program update
02/05/2022 at 20:22 • 0 commentsUpdated the Arduino firmware and Python upload program, to reliable upload hex files produced by z80pack/z80asm. New versions at https://github.com/electrickery/ROM-emulator.
Improved 2716 emupod wiring
12/21/2021 at 14:19 • 0 comments2716 28p cable header 24p socket header remark 1 A14 - connect to GND 2 A12 - connect to GND 20 CS* 18 CE* 22 OE* 20 OE* 21 Vpp connect to Vcc 23 A11 - connect to GND 26 A13 - connect to GND 27 WE* * connect to Vcc or the WR* signal 28 Vcc - not connected
ROMEmu assisted workflow
09/23/2021 at 16:19 • 0 commentsMy primary usage for the ROMEmu is writing and testing software for simple a Z80 SBC, the Multitech MicroProfessor MPF-I. The ROMEmu allows me to minimize the number of 'moving parts' while developing.
One time setup:
- connect the ROMEmu to the target system using a ROM or RAM socket mapped somewhere in the address space. For a startup ROM the SBC should be halted.Then it is mainly this iteration:
- Edit and assemble some code for the destined address in the target memory space on the cross-assembler PC,
- Upload the hex-intel file to the ROMEmu with the python script,
For example 'python3 romEmuFeed.py lcdtest.hex 2000' The second argument compensates for the address difference between ROMEmu and target system
- Execute the program in the ROMEmu memory. For the MPF-I this means 'RESET'; 'ADDR' 2000; 'GO',
- Evaluate the program and restart at the edit step. -
EmuPod & SocketAdapter information
08/02/2021 at 10:59 • 0 commentsThe EmuPod and SocketAdapter boards adapt the flat cable to a specific socket. The flatcable carries all signals from the 32kByte RAM, a 62256/D43256. The EmuPod transforms those to mimic the ROM signals. The SocketAdapter adapts to the physical socket form.
Each target ROM has a different pin layout, so expect to reserve a set of these boards for each ROM. Not all pins will change, thanks to the JEDEC standard, but some will. The ROMEmu optionally also allows writing to the RAM if a write signal is available, complicating the configuration somewhat. Unused address lines are connected to GND, to address the lower area of the RAM. An unused write signal is tied to Vcc.
Adding headers to the EmuPod:
- the cable header is placed on the component side, the side with the white silk-screen markings
- the socket adapter header is placed on the solder side. This to prevent the signals to be mirrored for the SocketAdapter. If you use a direct flatcable-socket adapter, then place the socket adapter header on the component side too.
SocketAdapter remarks:
- the header from the EmuPod is placed on the component side, the pins to the socket on the solder side. Make sure you use special socket headers with round pins, the usual flatcable header pins are to big. To protect the socket header pins from breaking off (and having you to resolder the header!) place at IC-socket on them. These are much easier to replace.
Some EmuPod wiring configurations. Only the 2532 one is properly tested!
Note: the cable header numbering used is the not the standard Odd-Even order, but a Counter-Clock-Wise order, the same as used for I.C-sockets.
This is for the 2532 EPROM socket (EmuPod24/SocketAdapter24):
28p cable header 24p socket header remark 1 A14 - connect to GND 2 A12 - connect to GND 20 CS* 20 CE* 22 OE* 22 OE* 23 A11 18 A11 26 A13 - connect to GND 27 WE* * connect to Vcc or the WR* signal 28 Vcc - not connected - 23 Vpp connect to Vcc
This is for the 2732 EPROM socket (EmuPod24/SocketAdapter24):
28p cable header 24p socket header remark 1 A14 - connect to GND 2 A12 - connect to GND 20 CS* 20 CE* 22 OE* 22 OE* 23 A11 21 A11 26 A13 - connect to GND 27 WE* * connect to Vcc or the WR* signal 28 Vcc - not connected
This is for the 2716 EPROM socket (EmuPod24/SocketAdapter24):
This is for the 2764 EPROM socket (EmuPod28/SocketAdapter28):
28p cable header 28p socket header remark 1 A14 - connect to GND 26 CE2 not connected - 26 NC not connected 27 WE* - connect to Vcc or the WR* signal 27 PG* not connected
This is for the 27256 EPROM socket (EmuPod28/SocketAdapter28):
28p cable header 28p socket header remark 1 A14 27 A14 - 1 Vpp not connected 26 A13 26 A13 27 WE* * connect to Vcc or the WR* signal
This is for the 62256 RAM socket (EmuPod28/SocketAdapter28):
28p cable header 28p socket header remark 1 A14 27 A14 26 A13 26 A13 27 WE* 27 WR*
Fix for ROM Emulator 1.1 Mega boards
07/07/2021 at 06:58 • 0 commentsThe 1.1 board did seem to work in some conditions, but wasn't really universally usable. This is a fix for the board, making it compatible with the 1.3 design. I didn't need more boards, so haven't really ordered and build any 1.2 or 1.3 for testing. The modification for 1.1 described here does work.
- replace the 74LS02 at U2 with a 74LS27
- cut trace to U2-1
- cut trace to U2-2 (component side)
- cut trace between U2-6 and U2-7
- cut both traces to U2-12
- cut trace between U2-8 and U2-9
- connect U2-9, U2-10, U2-11 to U2-7 (unused port)
- connect U2-1, U2-2, U2-13 to U2-6
- connect U2-4 to U6-7 (H1, buffered board OE*)
- connect U2-5 to U5-1 (H0, buffered board CS*)
- connect U2-12 to U3-19 (board read)See the boardPatch1.1to1.2.jpg image
ROM-emulator application
12/26/2020 at 21:08 • 0 commentsAn usage for the ROM-emulator just went live at GitHub: https://github.com/electrickery/Z80SerialMonitor
