MRU mode
A project log for LRU
Scratching the itch of Least-Recently Used algorithms and topologies. I found something funny.
yann-guidon-ygdesYann Guidon / YGDES 04/30/2024 at 13:190 Comments
To implement on-the-fly MRU, it's simple:
That's it.
This takes precedence over the rest so adds a layer of MUX and some latency...
preliminary interactive playground here.
The added MUX layer is quite OK for the A output:
A <= S when MRU='1'
  else B when A=S
     else A;
Easy !
But for B the equation is more complex.
If MRU='1' then
  if A=S then
    B <= A;
  else
    B <= B;
  end if
else
  if ... then
    B <= newB;
  else
    B <= B;
  end if;
end if;
This "folding" else is not obvious to redesign. Ideally only a pair of MUX2 should exist.
And let's not forget the WB output.
Here is another temporary version.
But I have finally found a trick by swapping the MUX, giving more time for the decoding logic and reducing redundancies. The current version is there:
The logic depth is about 5 gates and it supports both LRU and MRU modes. The approximate number of CMOS gates is 30, though going down to NOR/NAND logic could bring some enhancements, by sharing inverters for example.
Can I consider the case closed ?
I don't think so because I'll have to transcribe it to VHDL and then stress-test it with simulated worloads.
That will come later :-P
